Originally posted by UncleVanya It is going from normal to moderately wide while the 43 went from long normal to short normal. What about the 31 left you underwhelmed?
Pretty much. I'd gotten used to how the 31 performs on the k-3, so when I'd gone out with it on the k-1, i just kept thinking that I wish I'd had the 43 or 77 on
(so could just be my familiarity with that field of view)
The 31 does seem to suffer more flaring and blown highlights when mounted on the k-1, so I've generally been using it at -0.7ev (I think I'd consider a dfa31 if they update it with newer HD coatings). I think it's just a question of getting used to how it performs really. It might also be related to the FA43 and FA77 being such superb performers on the k-1. They are just unbelievably easy lenses to use, but I think the FA31 requires a little bit more work to get the most out of it. There is a slight lack of focus points at the edges of the frame on the K-1. With the 31, to maximise the bokeh, if you're like me you'll like focussing on subjects near the edge and corners of the frame. I found myself using manual focus frequently as a result.
It half reminds me of when I first got the DA21. I found that to be a strange lens to get used to. I suppose now I generally err towards f8 on that lens, with occasional forays towards f3.2. I think the FA31 will need a similar pattern, but it's just mentally harder to do that, because you know it's good wide open, but the kind of shots you're likely to take will be needing f8.
Looking back over the shots I've taken with it, it does produce some nice images, so it seems to do the job quite nicely. I just find the 43 and 77 to be much more fun to play with!
