Originally posted by Lampo Thanks! But this is done manually after focussing, I thought there was also a setting where the magnification is automatically activated when the shutter is pressed halfway. But perhaps I am misstaken.
The reason I ask, is because of the narrow field of depth when I use my old manual lenses. Focus peaking is great, but when the subject is further away, it is still hard to see when focus is correct.
It is full manual, so it can be done whenever you like, before, during or after focusing
Sony implementation is exactly like that: you have automatic magnification with focus peaking when you press shutter button.
On Pentax it is actually opposite, you activate magnification manually and when you press shutter button magnification is disabled not enabled.
I like Pentax implementation more because I don't need magnification always and I always want to check final composition without magnification before pressing the shutter button.
Only option what I want from Sony's implementation is changing of focus peaking color.
