05-31-2016, 12:09 AM   #136
Tas
Finally have some photos of my problem
Today I had my phone with me to capture some images of the issue I am having with my K-1.
I was outside in bright daylight when it occured so unfortunately the reflection off the screen has made it hard to show what I am seeing.
The two images following show my K-1 in LV and what appears to be a bracket. The bracket being black means the bracket is hard to define as the screen is reflecting an image of my phone. However you can see the LV working as the scene can be identified around the bracket at the top of the screen and through some slots on each side of the bracket.
So as you look at these photos what do you think I'm looking at (when you also consider the previous thread entries I've posted on this issue)?
I will be returning this camera, but for now it would be interesting to see what you guys think and whether anyone else has had this issue.
Tas
05-31-2016, 05:33 AM   #137
G_Money's Avatar
QuoteOriginally posted by WPRESTO Quote
I was experimenting with my K1 and 360II strobe using live view in my "studio" (=the basement). The LV screen remains bright in P, Sv, Tv, Av, TAv, X and B settings on the E-Dial. Only when set to "M" does the screen go light/dark when the aperture, shutter speed or ISO is changed.
Somewhat related item I noticed some time ago, and apologies if this has been answered. When the white balance is pressed on the 4-way controller. the options that come up include "Auto White Balance (AWB)" and "Multi Auto White Balance." How is this Multi AWB different? What does it do? I can find nothing in the manual that describes the what, when, and why, of multi AWB versus ordinary AWB.
Also, there is no setting for FLASH as on previous Pentax digitals. Is flash white balance now automatic? Does it function for both PTTL and manual strobes triggered via the PC socket? Is it set before the flash fires or applied post-exposure when the image is saved? Does it work the same way for both JPEGS and RAW?
From p.63 in the manual. "When (multi-auto white balance) is set,even if various light sources are present at the shooting location, the camera automatically adjusts the white balance according to the light source of each area." Basically it will use different WB settings in different areas of the same image. For example an interior lit by tungsten lighting where a window has an outdoor view, in theory both these areas should have their appropriate white balances set. The K-3 had this feature as well.
05-31-2016, 05:50 AM   #138
QuoteOriginally posted by Tas Quote
Honestly, the image is so badly shot, I can barely make head or tail of what you are talking about.
05-31-2016, 08:43 AM   #139
WPRESTO's Avatar
QuoteOriginally posted by G_Money Quote
How about white balance for flash/strobe. Is it now the same as daylight? Does AWB "know" there's a flash in use and consequently will not adjust for ambient fluorescent or tungsten? More critical: are all white balance adjustments made after the shutter fires = as the file is being saved?
05-31-2016, 10:58 AM   #140
Tjompen1968's Avatar
There are a few settings regarding how WB acts with flash in the C-menu
05-31-2016, 11:36 AM   #141
WPRESTO's Avatar
QuoteOriginally posted by Tjompen1968 Quote
Thank you, I'll be sure to look an "C" that.
05-31-2016, 01:46 PM   #142
Is this the same flash you are using for both issues or did you have a manual flash on the first question?
No, It was not the same flash, and to test I did now mount my fgz and switched it to manual, it stopped at 200 and would go down to 1/160 directly. Tried again with a godox TT520 no limit at all it just jumped past 1/200 as if there was no communication from the flash at all saying it was a problem (sarcasm). It does in fact seem to be my flash, a yongnuo ring flash made for a canon but set to manual mode. Apparently there is some communication, and it creates some bug in the Pentax firmware.
05-31-2016, 02:07 PM   #143
Tas
I agree, but when it happens I get about 15 seconds then the codition disappears.
As this only occurs occasionally I will try and replicate it where I can better control the light not when I'm out taking photos. If not then I will leave it as is.
Thanks for the feedback anyway.
Tas
05-31-2016, 02:20 PM   #144
Ariis's Avatar
AF fine tuning not completly working
I'm experiencing some inconsistent focusing with my Tamron 70-200 F/2.8 ("A001"), so I tried the fine tuning mechanism in C4-25, "per lens" mode, but I can set it to any value, it doesn't change anything !? I've made a the test with camera on tripod, clear and isolated thin subject, center spot AF, AF-S mode, and F/3.5 to have a shallow dof @ 200mm. I put the AF "far away" between each shot. I can understand that this is an extreme condition (?), but the point is that the AF adjustment is inoperant here.
With my Pentax DFA 100mm F/2.8 WR, it has an effect, but with a -10/+10mm range. Is this the range we should expect ?
---------- Post added 31-05-16 at 22:42 ----------
I also experienced something weird today, still with my Tamron 70-200 F/2.8 : in LV mode, I tried to auto-focus on a pine tree trunk that was 25m away, but the K-1 kept focusing alternatively on a closer thinner subject (~18m) and a farer subject (~35m) at each press. I was in AF-S mode, AF spot set to the center of the image, and the trunk was wider than the white square of the AF location, so it really shouldn't have missed it ! There was enough light (beginning of the evening). I pressed 6 times on the AF buttons and it kept focusing on those 2 subjects alternatively, outside of white square. I don't remember the aperture, it was F2.8 or 3.5 I think. Perhaps that F2.8 @ 200mm is too soft for proper LV focusing ? But in this case, it should focus on something and show a red square when locking, not a green one.
The local contrast of the pin tree was not that high, but still quite distinguishable (gray with spots on it). Can the K-1 ignore the selected spot location if it find something more contrasty just around it ??? If so (but it shouldn't), there should be a visual feed-back.
06-01-2016, 12:43 PM   #145
QuoteOriginally posted by Ariis Quote
I put the AF "far away" between each shot. I can understand that this is an extreme condition (?), but the point is that the AF adjustment is inoperant here. With my Pentax DFA 100mm F/2.8 WR, it has an effect, but with a -10/+10mm range. Is this the range we should expect ?
I do have good AF results with the K1 and Tamron 70-200. Also, I tried to correct for some front focusing on the DFA150-450 and it seemed to have nearly effect. The AF fine tuning on the K3 wasn't very effective, but my first impression is that it's worse on the K1. It seems that the amount that can be tune is really small.
06-01-2016, 01:25 PM   #146
Ariis's Avatar
Yes, and I suspect that the correction amount depend on the focal, i.e. the longer the focal, the smaller the correction for a given value. For my DFA 100 F/2.8, I have to correct to -6. For my new Tamron 28-75 F/2.8 (just got it today), I have to correct it to -10, and it's still not sufficient ! I think that it would really be interesting to be able to cumulate the global correction (to compensate imprecise AF sensor mounting) + per lens correction. Otherwise I need twice the actual correction range. But this doesn't answer to the non operant fine tuning for the Tamron 70-200, which I can barely use on the longer end if I want good AF. Perhaps something is wrong with the correction/focal length relationship.
---------- Post added 01-06-16 at 22:06 ----------
As explained here for the K-3, the K-1 behaves the same. To sum it up, the image is way darker when playing the movies on screen that on camera. Just look at the dark areas. You can even see the difference when using a monitor connected the the camera through the HDMI port.
I don't understand why nobody else noted that, but it clearly seems to be a bug in the codec or tags ? Just make the test that I explained there. I don't know if it's related to the REC 709 support by MOV files ? This make video recording with K-1 totally unusable.
06-01-2016, 04:22 PM   #147
My Tamron 28-75 requires identical correction on K-1. But it also requires similar correction on the K-3, but not so much on the K-5, and on the K-x it is perfect. It's a strange lens. Under most circumstances the correction comes close enough to give good results, especially if you shoot f3.5+.
I agree that it would be nice if the range of K-1 in-camera AF correction could be expanded. +/-10 just isn't enough sometimes.
06-01-2016, 04:42 PM   #148
clackers's Avatar
All PDAF sensors focus on a vertical or horizontal line, Ariis, not an area, however much we'd like that.
That's why you do focus tests with black geonetric patterns on a white background.
My Tammy 70-200 is fine with the K-1, BTW.
06-01-2016, 10:25 PM   #149
LaurenOE's Avatar
After my last "cry-wolf" bug...I'm embarrassed to ask if this is a bug.
When upside down (in video mode or live view), the K1 does great with turning the video around, but not the settings on the screen.
Is this a bug?
06-01-2016, 11:12 PM   #150
Yes, and I suspect that the correction amount depend on the focal, i.e. the longer the focal, the smaller the correction for a given value. For my DFA 100 F/2.8, I have to correct to -6. For my new Tamron 28-75 F/2.8 (just got it today), I have to correct it to -10, and it's still not sufficient ! I think that it would really be interesting to be able to cumulate the global correction (to compensate imprecise AF sensor mounting) + per lens correction. Otherwise I need twice the actual correction range. But this doesn't answer to the non operant fine tuning for the Tamron 70-200, which I can barely use on the longer end if I want good AF. Perhaps something is wrong with the correction/focal length relationship. ---------- Post added 01-06-16 at 22:06 ---------- As explained here for the K-3, the K-1 behaves the same. To sum it up, the image is way darker when playing the movies on screen that on camera. Just look at the dark areas. You can even see the difference when using a monitor connected the the camera through the HDMI port. I don't understand why nobody else noted that, but it clearly seems to be a bug in the codec or tags ? Just make the test that I explained there. I don't know if it's related to the REC 709 support by MOV files ? This make video recording with K-1 totally unusable.
Normally, the LCD brightness can be changed and the perception of its brightness is relative to ambient light. Therefore, with any camera brand, you never ever adjust exposure according to how it looks on the rear display but you must adjust exposure in order to have a centered histogram (Canon DSLR users do the same, they look at the histogram). Now if you really want do adjust your video exposure from camera LCD brightness, you can still tune the LCD brightness down in order to get satisfaction (yes you can tune rear LCD brightness to your taste). When using a camera, two things to consider: 1) bugs = the camera does not behave according to specifications 2) not using the camera in the correct way.
af-2, camera, card, clicks, dcu, dng, dslr, firmware, flashes, format, full frame, full-frame, issue, issues, k-1, k1, lens, lenses, list, metz, ok button, p-ttl, pef, pentax, pentax k-1, post, report, thread, time
WIN A K-1!!! Ricoh North America bertwert Pentax K-1 38 04-18-2016 07:03 PM
Computer specs for K-1 Post Processing loveisageless Pentax K-1 14 03-20-2016 11:39 AM
Ricoh Image Sync v1.1.0 app supports K-1 rawr Pentax K-1 6 03-12-2016 09:13 PM
Ricoh GXR + A16 users' feedback SOldBear Ricoh GR 7 03-06-2013 05:14 PM
All times are GMT -7. The time now is 01:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
