Originally posted by sammycat My K-1 is great when it works, but that's the rub. I've owned the camera a little less than two months, and I'm finding that it won't work with several of the A-Series lenses. Specifically, three of my go to A-series lenses (Pentax A 24mm/f2.8, Pentax 35-105mm/f3.5, and a new Rokinon 14mm/f2.8) that work well with other my other three Pentax cameras will not work on the K-1 (the lenses never reach focus at infinity). I first noticed this problem when trying to print (the detail was really soft), and then I confirmed it with Live View and 16x magnification (if just using focus confirmation, the camera will say it's in focus when in fact it is not--this becomes very apparent in Live View).
Is anyone else seeing this issue, or did I get a lemon?
Do you get the same results after doing focus adjustments on the lenses in question?
I use a number of manual focus lenses and found that the focus confirmation appeared hit and miss. I did a focus check and found I needed to do an adjustment for my manual lenses. I did a global adjustment and this fixed the problem.
I checked the adjustment with my auto lenses and all was good until I bought the 15-30 f2.8. The focus was way off so I set an individual lens focus adjustment and now that's fine as well.
Still, if I am on a tripod I will use LV and focus confirmation like you did as I know it will be spot on.
Tas
