Originally posted by Schraubstock K-1 Flaw Report
I am afraid I have to add another observation of the same problem.
Today I changed the lens from the Tamron 24-135 and mounted the 150-450. First boot up with the 150-450 worked o.k.
Second boot attempt, no luck. Camera did not boot. I flicked the switch back and forth a few times without success. I did not remove the battery this time but waited approx. 15 seconds but still no success. Waited another approx. 30 seconds but camera still was not able to be turned on. However after another 30 seconds the problem disappeared and I could now fire up the camera. Following all that the problem did not re-appear for the rest of the day.
Cheers
---------- Post added 12-05-16 at 06:20 PM ----------
Hi
I am afraid I have to report another problem.
Instant review is playing up sometimes. After a shot is taken the review appears automatically according to the setting in camera menu page 5.
From time to time the image review after a shot was taken will either not show at all or be seen only for a fraction of a second. Turning camera on and off will not reliably remedy this problem and it will often take a number of off-on activations to finally get the review stay in place for the time it was nominated to do so in the menu. I have tried all settings from 1sec duration to hold, the problem as described above remains.
The problem is not consistent, I can go for hours without it happening and then suddenly it will show up for the next four or 5 shots. It is also not lens specific.Very annoying.
Cheers
