Originally posted by Tas Today I had my phone with me to capture some images of the issue I am having with my K-1.
I was outside in bright daylight when it occured so unfortunately the reflection off the screen has made it hard to show what I am seeing.
The two images following show my K-1 in LV and what appears to be a bracket. The bracket being black means the bracket is hard to define as the screen is reflecting an image of my phone. However you can see the LV working as the scene can be identified around the bracket at the top of the screen and through some slots on each side of the bracket.
So as you look at these photos what do you think I'm looking at (when you also consider the previous thread entries I've posted on this issue)?
I will be returning this camera, but for now it would be interesting to see what you guys think and whether anyone else has had this issue.
Tas
This happened to me over the weekend. Plus two other interesting glitches.
I was shooting a high school graduation. Indoors with my Sigma 70-200 all was fine. When the ceremony wrapped and moved outdoors (very bright and sunny and about 83 degrees) I switched to my Sigma 24-70.
The "glitch" happened first. Now I'm not certain it was a glitch yet or something I did, but after several rounds of high speed continuous shooting of kids exiting the building, I would stop, then shoot again as more kids came out. Suddenly I couldn't shoot. It was as if the buffer was full (I don't believe it was), but it was several or more seconds before I could do anything again. Later, it didn't happen at all. I need to see if I can recreate this before declaring it a bug.
The second glitch relates to apparent over exposure as shown on the preview. I was shooting in TAv mode, and after a good number of normal shots the preview started suddenly showing me blown out exposures. I couldn't figure it out. At one point in a panic I dropped the EV compensation way down and that seemed to help as far as the preview was concerned. However when I got home and offloaded the RAW files, all the photos that were "overexposed" where spot on, and the ones I compensated with EV where underexposed. Weird!
I did see Tas's issue too. I had both on purpose and accidentally switched to and from Live View (for some over-the-crowd shots, other times by accident because I am used to the Play button being elsewhere on the K3), and on more than one occasion the camera would fail to return fully from live view, whereby the mirror seemed to be stuck in the up position and the view finder was black. Other times Live View would only show at the top 1/4 of the screen with the bottom 3/4 mostly black. Again, as if the mirror wasn't fully actuated in the correct direction.
Curiously, after power cycling the camera for one of these episodes, the overexposure problem I mentioned above suddenly went away,
Because of the shooting situation I was in, I couldn't troubleshoot and just power-cycled to clear the problem in order to move on.
Will investigate and try to replicate at a later time when my schedule clears. In the meantime I just wanted to give a "me too" to Tas.
