05-02-2016, 10:01 AM   #16
RGlasel's Avatar
1:1 is trendy now. In a few years it will be passť.
It's the revenge of the Philistines, anyone with an appreciation for artistic beauty and design knows that a square needs to be placed inside a visual container with unequal proportions, squares are unbearably crude by themselves. If the Golden Ratio was good enough for Euclid, it is good enough for me. 1:1 might work for a Cyclops, but it is unnatural for anyone with stereoscopic vision.
05-02-2016, 10:47 AM   #17
thibs's Avatar
QuoteOriginally posted by RGlasel Quote
On what good authority? Just because?
I must not be everyone. Ouch.
05-02-2016, 11:44 AM   #18
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by thibs Quote
@Monochrome: I don't think so. It was always limited to 6x6 mostly and it is quite difficult to frame. But done well, it kills other formats IMO (YMMV of course)
Well, I was on the front side of the film plane and I've never handled a 6x7, so. . . My bad.
05-02-2016, 11:53 AM   #19
Not a Number's Avatar
I haven't shot 1:1 since I stopped using my 127 film Kodak Flashfun Hawkeye camera in the late 60s and Polaroid cameras in the mid-70s.
05-02-2016, 07:10 PM   #20
automated crop on import for tools like Lightroom
This can't be fully automated in LR yet, unless I am missing something.
I guess one would first manually create a preset for the crop ratio you want, then save that preset, then apply that preset upon import to a copy of the image in LR. And hope that LR applies the preset crop to the correct area of the full image.
05-02-2016, 07:15 PM   #21
It's easy enough to do a batch crop in Adobe Bridge or create a macro/script in Photoshop. I've done it both ways.
05-02-2016, 07:21 PM   #22
Wheatfield's Avatar
Any confirmation if 1:1 square crop is enabled in production firmware?
Thanks.
Not that I've seen. I picked my K1 up this afternoon and have been through the entire menu several time. I think people who want 1:1 or any other crop will have to do it the hard way.
05-02-2016, 07:24 PM   #23
But Lightroom?
Also if, for example, you want a 1:1 crop, how do you tell the import process that you want the 1:1 crop to apply 10 degrees to the left of the image centre, not at the dead centre of the frame, for example?
05-02-2016, 08:30 PM   #24
A big fan of the old 1:1 here. It's hip to be square. Working with a 6x6 Rolleiflex taught me that long ago. The format lends strength to compositions of three main elements, forming an unbalanced dynamic that pushes and pulls against the balance and repose of the square. Yes, we talked like that back in art school.
05-02-2016, 08:30 PM   #25
RGlasel's Avatar
I thought I read somewhere else that the mind-reading brush will be a new feature for LR 7. Moving the 1:1 crop overlay away from centre with a mouse is a pretty straightforward process, but left to its own devices, LR does seems to centre the overlay to the centre of the image. I'm guessing the developers of LR just made the assumption that anyone who wants to move the crop overlay from the centre of the image is manually processing their images.
Perhaps I missed a sarcasm tag, but the company here that does tens of thousands of school pictures has someone visually check the cropping for the different print sizes offered and make manual adjustments to avoid unintended haircuts when they switch from 4x6 to 5x7 for instance. There is a point where automation is a hindrance, not a help.
05-02-2016, 08:31 PM   #26
But Lightroom?
Easy enough to make the change on one image and paste the crop settings to the others.
05-02-2016, 09:28 PM   #27
Wheatfield's Avatar
QuoteOriginally posted by kvetcha Quote
I get the feeling that some people would be happier with a robot that they can send out to take pictures for them while they sit on the couch watching Oprah reruns.
People, some of this stuff requires user intervention.
It's called the creative process.
Is it really that hard to frame a picture and then crop it in post?
05-02-2016, 09:43 PM   #28
That's true. But still very manual.
Ideally, I guess, as you import the image RAW, LR would read the camera EXIF and only show in Library mode the cropped image, including if applicable the ratio (eg 1:1) that was used when LiveView was used to frame the shot.
I wonder if the LiveView crop framing perspective is recorded in the EXIF? If yes, that info could certainly be accessible for scripting.
---------- Post added 2016-05-03 at 02:46 PM ----------
It doesn't bother me, since I don't use fancy crops like 1:1.
But if you were processing 200 shots (school portraits or something, perhaps), some automation would be handy.
05-02-2016, 09:48 PM   #29
I don't use LightRoom, never had and know for nothing about it.
Adobe Bridge you select the RAW files you want to work on in the browser and open them in Bridge. Click select all. Apply the crop any any other adjustments you want. Click "synchronize", check "crop" and any other adjustments you want applied to all selected. Click "appy/ok". Click "done". Then run image processing from Bridge to develop the RAWs
05-02-2016, 09:57 PM   #30
thibs's Avatar
Well, try to frame a square picture in rectangular one.
Crop lines in VF are the absolute minimum otherwise yoill is the target or do it fuzzy way.
We don't use a DSLR with glass prism and 100% FoV to frame a picture +/-10% and crop it later in post. My smartphone is there for such uses.
I'm sorry but there's no point in framing if I have to do the job again. The creative process is supposed to happen when taking the picture not ad an after thought because I framed 4:3 and botched it so I 1:1 will kind of make it not too bad.
Well, YMMV of course, this is just me.
---------- Post added 03-05-16 at 05:58 ----------
Thanks for checking !
crop, crop settings, dslr, exif, frame, full frame, full-frame, image, k-1, k1, liveview, pentax k-1, picture, post
Can a K-1 owner confirm 1:1 square crop shooting option? peterm1 Pentax Full Frame 46 04-30-2016 03:34 PM
Kenspo! crop 1:1 question. Gimbal Pentax K-1 31 02-21-2016 11:48 AM
For Sale - Sold: The Bokina! Vivitar Series 1 (Tokina) 90/2.5 macro (NEW & IMPROVED!) w/ 1:1 adapter vonBaloney Sold Items 3 09-23-2015 11:10 AM
K30 question about "crop sensor" and 1.5x crop mellowyeahlow Pentax K-30 & K-50 19 12-15-2014 03:14 AM
645DII - 50 MP with crop 1.1. - is it good upgrade? ogl Pentax News and Rumors 58 09-11-2012 04:55 AM
All times are GMT -7. The time now is 12:45 AM. | See also: NikonForums.com, part of our network of photo forums!
