05-04-2016, 05:28 PM   #16
clackers's Avatar
QuoteOriginally posted by Jure Quote
@ Class A
I just found out how to get ideal photo:
I have to combine two of them:
one with & other without astro-tracker.
Correct. Light paint some foreground objects for bonus points.
05-04-2016, 06:01 PM   #17
bobmaxja's Avatar
Downside of Astro-tracker:
stars are sharp, but other motionless objects in photo are not.
PC Magazine
Any solutions?
This is not a bug !!!!!!!
05-04-2016, 06:07 PM   #18
PC Magazine
Any solutions?
Shoot 2 photos
05-04-2016, 09:46 PM   #19
i83N's Avatar
Don't engage the astrotracer.
This will produce sharp motionless objets but fuzzy stars.
You cannot have both at the same time, unless you make a composite in post-production where the unsharp bits of one image are masked out. Not hard to do.
Actually you can, just need to flash unmoving object in first seconds of exposure.
05-04-2016, 10:16 PM   #20
clackers's Avatar
QuoteOriginally posted by i83N Quote
Or the last few seconds, what does it matter?
In any case, that'll make two images of the same object - one brighter and sharp, the other fainter and blurred.
Best to do this as a composite.
05-05-2016, 12:21 AM   #21
K-amps's Avatar
Agreed... The purist approach would be to use the best of both shots.
05-05-2016, 01:25 AM   #22
Jure's Avatar
Jure
Read more at: https://www.pentaxforums.com/forums/190-pentax-k-1/319873-post-k-1-bugs-issue...#ixzz47ldDY1Rp
@ bobmaxja
@ Adam
@ i83N
@ clackers
@ K-amps
Hi dear friends!
Did you read my second (quoted) comment?
No?
Why not?
05-05-2016, 01:48 AM   #23
@ bobmaxja
@ Adam
@ i83N
@ clackers
@ K-amps
Hi dear friends!
No?
Why not?
If you put a space after the @ sign, the referenced users won't get a notification. Use this format: @Jure
05-05-2016, 02:09 AM - 1 Like   #24
Jure's Avatar
Tnx Adam ... I didn' know that.
05-05-2016, 02:40 AM   #25
clackers's Avatar
Hey, Jure ... if you put a space after the @ sign, the referenced users won't get a notification. Use this format: @Jure.
Just tugging your chain! ☺
05-05-2016, 03:19 AM   #26
K-amps's Avatar
@ bobmaxja
@ Adam
@ i83N
@ clackers
@ K-amps
Hi dear friends!
No?
Why not?
Sir Jure... you said it first! Gave u a like to make up for the lapse
05-05-2016, 11:26 AM   #27
Class A's Avatar
QuoteOriginally posted by K-amps Quote
Actually, I did.
Apparently, that's a fact that evaded Jure as well, so it is a bit ironic that he is pointing out to others that they should be reading posts properly.
Enough with the fun and I'll admit that my attempt at helping could have been expressed more clearly.
05-05-2016, 11:51 AM - 1 Like   #28
This is probably operator error but my sigma 120-400 will not work on my k1(it does work on the k3). The camera will not do anything with that lens attached.
This is my fist day with the K1 so I'm probably missing something. Any suggestions/ corrections are appreciated.
Thanks
Tammy
05-05-2016, 11:51 AM   #29
Jure's Avatar
Actually, I did.
You must be a very sensitive man - what is a beautiful characteristic of artists.
YESSSS ... I admit - mea culpa, mea culpa maxima ... In spite that I mentioned your nick in my second comment I forgot extremly to point out the contribution of yours. I just didn't think of that (for you) very important point of view.
I apologize with all my heart - it will not happen again!
05-05-2016, 03:45 PM - 2 Likes   #30
gryhnd's Avatar
Brief tests just firing off a few shots.
My Sigma 70-200 2.8 DG HSM operates correctly.
So does the Bigma 50-500.
My Metz AF2 would not fire though at any speed. Setting the Metz to HSS as mentioned by @pid solved that, so there's a temporary fix.
---------- Post added 05-05-16 at 06:47 PM ----------
QuoteOriginally posted by G_Money Quote
When mounting a Sigma 12-24mm EX DG, camera will sometimes (but not always) ask to have focal length input, even though this lens doesn't require this for use with a K-3 or K-5. If I enter the default 100mm and then try to check it in the menu, the focal length item in the menu (camera 4) is greyed out, as it should be for a lens with the appropriate electrical contacts. Examining the EXIF data of an image shot at 12mm, the focal length appears as the correct 12mm. I realize that it's probably a Sigma firmware issue, but I'm surprised that it doesn't happen every time the camera is turned on with this lens mounted.
Try cleaning the contacts of the lenses. This happens to me on my workhorse lenses every couple/few months depending on use.
I'll clean the camera contacts at the same time of course, but the K1 shouldn't need that.
aperture, apo hsm, camera, change, dslr, exif, exposure, firmware, full frame, full-frame, hsm, id, issues, jpg, k-1, k1, lens, lenses, pentax k-1, shutter, thread, tv
Post K-1 bugs/issues (feedback for Ricoh) Adam Pentax K-1 410 06-23-2017 07:32 PM
Not just another "K-5 or K-50" thread....... twigfarm Pentax DSLR Discussion 10 04-17-2015 05:19 AM
pentax k 30 troubleshooting nicks.narain Troubleshooting and Beginner Help 9 02-14-2015 08:54 PM
Question new thread and leave feedback Rimfiredude Site Suggestions and Help 12 02-12-2015 07:38 AM
Misc Bugs (no, not real bugs...) Julie Post Your Photos! 8 04-12-2014 02:19 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
