05-03-2016, 05:59 AM   #46
QuoteOriginally posted by Giklab Quote
I have a K-5II and it does that. Maybe they changed the behaviour from the classic to the II? Then again, mine had the sensor assembly replaced a while ago due to a SR error, so maybe it's that? Strange.
That IS weird, can you actually hear the SR mechanism work while you half-press the shutter button?
05-03-2016, 09:47 AM - 2 Likes   #47
I have K-5 and K-1.
I can confirm that my K-5 does NOT activate sensor motion with half-press, and only indicates the SR 'hand' about 0.5 sec after half-pressing the shutter release.
The K-1 shows the SR 'hand' at power up, then activates sensor motion with half-press that continues until about 0.5 sec after un-pressing the shutter release.
The 'loose ball bearing' sound of the unpowered camera is much greater with the K-1; though hardly surprising given the much larger sensor assembly.
I presume the K-1 behavior gives faster response. The back AF button also activates the sensor motion.
05-03-2016, 11:16 AM   #48
Interesting.
That means half-pressing on a K-1 will draw a lot more current from the battery than half pressing does on a K-5. Not really a good development from a power preserving point of view, but I guess they have their reasons.
05-03-2016, 11:46 AM   #49
QuoteOriginally posted by Gimbal Quote
Yep. I'll try to double-check with someone here. But as the K-1 does this, maybe it was introduced at some point?
05-07-2016, 08:25 AM   #50
Ok, I'm new to Pentax, admission made. I just pulled my camera out of the packaging for the first time, moved it around a bit and...clunk, clunk. I was like, holy xxxx, my camera's broke. I'm really glad to have found this forum, I'm a happy camper again🤓.
05-07-2016, 02:31 PM   #51
Interesting.
Conjecture: Moving the sensor into position before shutter press instead of after was done to meet more demanding design criteria on the K-1. Namely, a reduced shutter lag time* and increasing SR effectiveness from 4 to 5 stops. And doing so with a sensor assembly of ~ twice the mass.
* There is a PF post where someone measured K-5 shutter lag to ~ 0.1 sec. Imaging Resource, I think, lists the K-1 shutter lag at < 0.05 sec.
05-07-2016, 03:14 PM   #52
clackers's Avatar
QuoteOriginally posted by m144k Quote
Er, just remember the two clips for the strap do slap against the body as well ... something to bear in mind. ☺
05-08-2016, 01:55 AM   #53
Not if you use the leather-ish pads
05-08-2016, 05:24 AM   #54
clackers's Avatar
Yeah, I'm just saying that sound may not be the sensor rattling!
camera, delay, dslr, full frame, full-frame, half, k-1, k-1 whats, k1, mirror, pentax, pentax k-1, position, post, press, sensor, shutter, view
Just bought a K-3 whats wrong with it imdunn513 Troubleshooting and Beginner Help 18 05-04-2015 12:26 PM
Rear lens extender 1.4, by pentax, whats the VERDICT?? photoramone Pentax SLR Lens Discussion 13 01-24-2015 11:28 AM
whats a good case to carry the pentax mx-1 on my belt tootal2 Pentax Compact Cameras 5 07-19-2014 07:47 AM
SMC Pentax M 1:2 50MM. Whats it good for?? s1120 Pentax SLR Lens Discussion 32 05-15-2013 07:53 AM
whats the difference? 1:1 vs. 1:2 macro metungnasi Pentax SLR Lens Discussion 15 04-06-2009 04:16 PM
All times are GMT -7. The time now is 09:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
