05-03-2016, 06:33 PM   #1
How to do a better manual focus in K1
Hi all, i got my K1 yesterday and tried my old SMC 55 MF lens. It is very good but to me it is hard to do the manual focus in the OVF. May I please seek u guys advice ? Thanks in advance.
05-03-2016, 06:39 PM   #2
You can use live view, and make sure to turn ON the focus peaking in the menus. You will see the things in focus highlighted in white
05-03-2016, 06:40 PM - 1 Like   #3
Otis Memorial Pentaxian
Conventional wisdom is that additional magnification may help. The favorite on this site has been the Pentax O-ME53 magnifying eyepiece. I have not personally used it, so cannot give a strong recommendation. Until such time as alternative focus screens with focus aides become available, this is the best solution at present for the optical viewfinder.
http://www.bhphotovideo.com/c/product/469574-REG/Pentax_30150_O_ME53_Magnifying_Eyecup.html
https://www.pentaxforums.com/accessoryreviews/pentax-magnifier-eyecup-o-me53.html
05-03-2016, 07:00 PM   #4
QuoteOriginally posted by kinkindoll Quote
Live view magnification is the way to go for precise manual focus.
You can also use AF confirmation through the viewfinder.
05-03-2016, 07:10 PM - 1 Like   #5
vinceloc's Avatar
Use the focus assist. When the green polygon shows up on the viewfinder and remains steady, shoot!
05-03-2016, 07:39 PM   #6
Wheatfield's Avatar
QuoteOriginally posted by vinceloc Quote
I haven't checked with non A series lenses, but with non AF A series, when focus is achieved a red flash can be seen for a moment in the viewfinder and the center spot turns bold.
I don't recall the setting, but it seems to work well.
05-03-2016, 08:11 PM   #7
With the OVF, using the 'Catch in focus' mode is another option. For example; when this mode is set the shutter release button is pressed and held, while the focus to the lens is rotated, then when the subject comes into focus at the user specified AF sensor (e.g. center sensor) the camera will automatically actuate the shutter.
05-03-2016, 08:24 PM   #8
PePe's Avatar
Pentax O-ME53 Magnifying Eyecup 30150 B&H Photo Video
PENTAX Magnifier Eyecup O-ME53 reviews - Pentax Camera Accessory Review Database
I moved my O-ME53 magnifying eyepiece from the K-3 to the K-1. Works fine!
05-03-2016, 08:48 PM   #9
QuoteOriginally posted by One3rdEV Quote
These two methods both use the PDAF system and are equivalent in regards to ability to detect an out of focus condition with catch-in-focus being somewhat less effective for real world use. When used with the center column focus points and a lens f/2.8 or faster both are about a stop better than the optical viewfinder with stock screen on the K-3. On the K-1, I am not sure which, PDAF vs. optical focus, is more effective (better focus sensitivity).
Probably the best approach is to do comparative tests with a non-ambiguous subject* tallying the number of successful (acceptably sharp) focus attempts out of 20 for each method.
* Typically a lens resolution test target mounted on a flat surface parallel to the camera sensor at about 20x - 40x the lens focal length. The aim is to make it as easy as possible to attain focus with the least number of uncontrolled variables.
05-03-2016, 10:54 PM   #10
Thanks all, i may consider to buy the magnifying eyepiece. I tried LV but cannot enlarge the focus area, a bit confused.
05-03-2016, 10:58 PM   #11
Once in LV, press the ok button to activate the zoom function, by default, should be 2x, turn the front wheel dial to change the zoom setting.
Hope i remember correctly.
05-04-2016, 12:10 AM   #12
Digitalis's Avatar
I can recommend it. I use an O-ME53 viewfinder magnifier, and it enhances the focus snap of the focusing screen. I have a similar VF magnifier for the Pentax 645D/Z.
05-06-2016, 12:56 AM   #13
Thanks all
05-06-2016, 08:53 AM   #14
wtlwdwgn's Avatar
I've been using my A series lenses and I find manual focusing a joy now.
05-06-2016, 09:56 AM   #15
artobest's Avatar
This may seem a bit obvious, but have you set the diopter adjustment on the VF to match your eyesight?
dslr, focus, full frame, full-frame, k-1, k1, pentax k-1
how to focus perfectly with manual focus lens? ghiaauto Pentax SLR Lens Discussion 17 09-30-2014 02:37 AM
How do you push yourself to be a better photographer? applejax Photographic Technique 52 01-09-2012 04:01 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
How do you know when a pentax dslr is in focus with a manual lens? justtakingpics Pentax DSLR Discussion 19 05-22-2010 04:06 AM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
All times are GMT -7. The time now is 11:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
