Originally posted by bestlym 1. K1 post cropped with 300mm 2. K1 with 450mm 3. K1 cropped mode with 300mm 4. K3 with 300mm well... It's my first posting in this forum.
hey hey, interesting ! ;-)
---------- Post added 05-05-16 at 15:26 ----------
Originally posted by Madaboutpix Okay, I guess I get it: Judging from the waste bin symbol, images #2 and #4 look a little sharper.
My impression is that #4 is one of the sharpest, yes.
---------- Post added 05-05-16 at 15:27 ----------
Originally posted by K-amps I am just guessing based on me taking a screenshot and lifting shadows to see noise pattern. 1 and 3 seem more organic and might be K1.
There are slight differences in noise, that's a good point, that may give a hint
---------- Post added 05-05-16 at 15:28 ----------
Originally posted by johnmflores My guess is that you have a 32GB SDHC card from Transcend that is made in Taiwan.
Originally posted by johnmflores By the looks of it, I'd guess it that the package was a 2-color job (black and red) instead of a 4-color process (CMYK mixed with dots much like a Bayer array) with a relatively coarse line screen of 150 lines per inch. And It's likely a 32GB Transcend SDHC card made in Taiawan. But that's only a guess.
LoL , gosh, how did you guess , :-) , that's a good start ;-)
---------- Post added 05-05-16 at 15:31 ----------
Originally posted by kvetcha 1 & 3 seem sharpest to me.
humm , yeah , depends on where in the frame
. Are they from the K1 or K3 ?
---------- Post added 05-05-16 at 15:36 ----------
Originally posted by VoiceOfReason Your cards are too small. I have a pair of 64gb ones in the K3 and a pair of 128gb ones that will be in the K1 when UPS drops it off tomorrow.
Well, I have 2 x 64Gb that I used in the K3, but the second slot was causing some random write errors with the 64Gb cards and the 32G always worked fine, so I use 64G in SD slot #1 and 32G in SD slot #2. In the K1 there are no issues with using both 64G in both slots. With 32G, that's a capacity of something like 700 RAW shots per card in the K3 and 400 RAW shots per card in the K1.
