05-08-2016, 02:27 AM   #1
Who has emptied their battery, and how long did it take?
I spent all day yesterday shooting a baptism reception and the battery is still at full bars. I'm wondering if anyone has drained the battery and how long it's taken - my K5ii tended to show high battery levels for ages and then drop like a stone, so I'm not sure how it's holding up.
05-08-2016, 02:54 AM   #2
My battery is still full since 4th May after it was charged overnight on 3rd May.
05-08-2016, 03:13 AM   #3
QuoteOriginally posted by Whateverist Quote
If you're not using flash, expect it to last more than twice the rated, with average display usage.
ISO constantly above 400 will be felt. Live view even more.
That sudden drop is present since, at least, the K10, and basically means around 400 left, with minimum display usage. Use flash or live view and you get low double digit count.
I've had mine shutdown during shooting, but didn't get bad files. Won't risk it again though. If you want to drain it, flash or live view, although I've heard prolonged live view isn't good for the sensor, hence the temperature reading when shooting video. That came along with stories of burnt Sony sensors...
Forgetting to turn power save back on will also help draining it
05-08-2016, 04:28 AM   #4
WPRESTO's Avatar
I guess the rules with batteries are: 1) they last longer than you'd think; 2) they only go dead when the best or most important image opportunities arise. I carry two extras, just in case I replaced one that ran out sometime back, then forgot to take it out of the camera bag for recharging.
05-08-2016, 05:01 AM   #5
QuoteOriginally posted by dafbp Quote
How would flash usage change the battery life, given that the K-1 has no built-in flash?
05-08-2016, 05:19 AM   #6
Moderator PEG Judges
Kerrowdown's Avatar
My batteries always seem to last for ever and I'm expecting the K1 to be no different, especially when I run a grip with a second battery in it. Now I can even also use batteries too if I get stuck with the K1 grip... couldn't do that with K20Ds.
But I'm not a "fair usage" person to judge by... as I'm on metering with it, as I'm manual focus only.
05-08-2016, 05:45 AM - 1 Like   #7
Lens Buying Addict
monochrome's Avatar
The first bar ~ clicks
The second bar 50 clicks
The third bar n-1 clicks, where n = number of clicks needed to finish.
05-08-2016, 06:06 AM   #8
QuoteOriginally posted by WPRESTO Quote
haha, well said
05-08-2016, 07:17 AM   #9
robgski's Avatar
I shoot my K-5 almost every day, often using Live View but only rarely using flash. I deplete and recharge the battery every three weeks or so. I carry a spare, because two is one, and one is none.
05-10-2016, 05:45 AM   #10
Ron_Man's Avatar
QuoteOriginally posted by funktionsfrei Quote
External flash using P-TTL will drain the battery. At least in my experience.
I've started using Cactus V6s and RF60s (on K-3) and notice the battery doesn't deplete as fast.
05-12-2016, 04:33 AM   #11
Thanks for answering the OP's question about battery duration and bar indicator accuracy
05-12-2016, 07:37 AM   #12
Not sure why you're picking out this comment, but the poster was asking about the reference to the flash in a previous post. Seems like a valid question.
The battery went to 2 bars after the weekend. Panic set in.
05-12-2016, 07:41 AM   #13
Tjompen1968's Avatar
Using the GPS for tracking when out shooting almost sucked the battery dry after 9 hours and 600 frames.
Without the GPS I find it to last just a little bit shorter than the K-3. I.e it is not the power hog I expected.
05-13-2016, 05:16 AM   #14
Because it wasn't a question.
05-13-2016, 05:26 AM - 1 Like   #15
Digitalis's Avatar
The real contest is who gets the first speck of dust on their full frame sensor!
battery, dslr, full frame, full-frame, k-1, k1, pentax k-1
How long did it take to break your camera gear? A survey AtitG General Photography 44 02-16-2016 06:20 AM
Nature How Long Does It Take? Rupert Post Your Photos! 11 12-06-2015 08:24 AM
Firmware Update - How long does it take? sholmes Troubleshooting and Beginner Help 4 09-09-2014 11:11 AM
How long did it take you to get your system 90% complete? slackercruster General Talk 20 05-09-2012 05:42 AM
it's killing me......how long will it take?? janstew Pentax K-5 25 03-28-2011 04:42 AM
All times are GMT -7. The time now is 07:39 AM. | See also: NikonForums.com, part of our network of photo forums!
