Show Printable Version 6 Likes Search this Thread
05-08-2016, 01:58 PM - 1 Like   #1
fwbigd's Avatar
Near Full Frame Performance of 70mm f2.4 Limited on K-1
Very surprising results. Only slight vignetting from the 70mm Limited when shot as a FF lens on the K-1.
PENTAX K-1  Photo
05-08-2016, 02:28 PM   #2
Na Horuk's Avatar
That looks great! What about focused at infinity and nearest focus? Just to test the extremes, as image circle can change depending on focus
Encouraging results, and great photo
05-08-2016, 02:36 PM - 1 Like   #3
Caat's Avatar
I've seen the DA 70mm used on film by several people. It's basically a 35mm coverage lens.
05-08-2016, 03:10 PM   #4
Tas
Was the hood on and extended?
QuoteOriginally posted by fwbigd Quote
Hi Darryl,
I am a big fan of this lens and hope to keep making regular use of it on a K-1 when I finally get one. I'd be keen on knowing more about the vignetting at different focal lengths as Na Horuk has asked and whether the hood was on or off and if the hood was on if it was extended or retracted.
I will check this for myself anyway but would be interested if you can expand on the hood set up for this image and any other examples you might be preared to share.
Oh, lovely horses BTW, they look like racing thoroughbreds, not that I'd really know.
Tas
05-08-2016, 04:11 PM - 1 Like   #5
fwbigd's Avatar
The lens hood was extended on all shots that I took. The lens performed very well all the way through the f stop range. The one below was taken at f10 with very little vignetting. The shot of the horses above was at f3.5.
PENTAX K-1  Photo
05-09-2016, 05:22 AM   #6
How does it perform at f/2.4?
Thanks.
05-09-2016, 07:53 AM - 1 Like   #7
fwbigd's Avatar
There is slightly more vignetting, but acceptable in my opinion.
PENTAX K-1  Photo
05-09-2016, 08:56 AM - 1 Like   #8
Thank you!
70mm ltd is one of my favorites, I feel relieved knowing that it can be used with K1.
05-09-2016, 02:51 PM - 1 Like   #9
Tas
Thanks for the feedback Darryl, I'll be going to the Australian launch in Sydney tonight, that'll be the closest I get to one for now, but it is encouraging to see that even if a wider hood won't help the vignetting should be easily addressed in PP. Now I just need to get myselif a K-1 too.
Tas
70mm, 70mm f2.4, dslr, frame performance, full frame, full-frame, k-1, k1, pentax k-1, performance of 70mm
What happens when you put an aps-c lens on full frame(K-1)? fstop18 Pentax Full Frame 8 04-13-2016 08:34 AM
Would AF film lens series produce full frame on K-1? fstop18 Pentax Full Frame 13 04-11-2016 02:23 PM
K-1 So What Is Full Frame Going To Provide Over A Crop Frame DSLR MRCDH Pentax Full Frame 312 03-22-2016 01:21 PM
Full Frame cropping performance. derekkite Pentax Full Frame 17 03-19-2016 03:44 AM
DA* 55mm f/1.4 on the new Full-Frame? Moropo Pentax Full Frame 13 02-05-2015 09:16 AM
All times are GMT -7. The time now is 04:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
