05-13-2016, 09:59 PM   #1
Can't get the exposure meter to activate?
Hi,
I'm new to the forum, and new to the pentax digital systems.
I'm having an issue I was hoping someone could help me with. I have a set of medium format manual focus lenses in Mamiya mount that I have had for years. I have successfully adapted these to work on cameras like the 5d II, d800e, and a fuji x pro1. I've never had an issue with these lenses until I got the K-1. I do have a good adapter to mate the lenses to the body, but for some reason, I cannot under any circumstances get the camera to show the exposure meter. This seems to go against most other camera makers, where when the camera is active the meter sits there and works when you half press the shutter or similar setup, reading through the stopped down lens. I understand that the lens would be used in manual only mode, and stop down metering would be in effect, but I can't get the camera to meter using either the optical viewfinder or the live view function. Am I missing some function buried in a menu somewhere?
I know it's an off the beaten path type of question, but any help would be appreciated!
05-13-2016, 10:14 PM   #2
jatrax's Avatar
Do you have a k mount lens available for testing? If so first verify the camera is working properly.
05-13-2016, 10:56 PM   #3
QuoteOriginally posted by pigtango Quote
Hi,
Switch to manual and press green button. Exposure changed or not?
05-13-2016, 11:05 PM   #4
Hi,
You need to change a custom function and ensure that you're in M mode. Instructions below:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
05-14-2016, 06:54 AM   #5
I was having this trouble with when a manual aperture ring on a lens was not set to "A". I would only get a DOF preview in the viewfinder.
camera, dslr, exposure, exposure meter, full frame, full-frame, function, k-1, k1, lens, lenses, meter, pentax k-1
Holy Metering Batman! I Wasn't Using the Exposure Meter jackloganbill Pentax K-30 & K-50 12 03-24-2016 05:23 AM
Can't Get the Firmware Update to Work bigted Pentax K-3 15 03-15-2014 08:32 AM
can't get to the pentax site!! Katmandude Pentax DSLR Discussion 10 12-06-2013 09:30 PM
Question Can't find the links page (trying to get a link to Eric's services) ismaelg Site Suggestions and Help 3 12-02-2010 01:15 PM
I can't get the in built flash to play nice twitch Troubleshooting and Beginner Help 11 03-10-2010 09:29 AM
All times are GMT -7. The time now is 03:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
