05-14-2016, 12:18 PM   #1
Moderator PEG Judges
Kerrowdown's Avatar
K1 SD slot selction question
Does anyone know how I can select which SD card does the recording of images when I'm in the sequential mode, I've found how to do it on playback but not recording.
Thanks in advance the old Kerrowdown's being a numpty I'm sure and before you say it... I have already RTFM'd the manual but without success.
05-14-2016, 12:28 PM   #2
QuoteOriginally posted by Kerrowdown Quote
There is no setting to do so. However, you can force the swap via a particularly tedious workaround.
Power off the camera, remove the currently-selected memory card, power cycle, re-insert the card, and turn the camera back on. The opposite card will now be selected.
05-14-2016, 12:31 PM   #3
Kerrowdown's Avatar
Thanks Adam, I'd found that way by kinda default, but thought there must have a simpler way, but not in this case it seems.
At least I feel a whole lot less numpty ish.
05-14-2016, 12:34 PM   #4
Not a Number's Avatar
Sounds like time for a feature request.
05-14-2016, 12:36 PM   #5
Oh I've been begging for a while
05-14-2016, 12:56 PM   #6
jatrax's Avatar
I have thought this 'feature' was a bug on both the k-3 and k-3II. Just did not make any sense. However, with the k-1 I am filling cards, which I never did before and I have discovered the logic behind it. Not saying it is right, but at least I understand what they were trying to achieve.
If you have your cards set for sequential when you fill card one it shifts to card two. Now you remove card one (as it is full) and replace it with card three. When card two fills the camera shifts to card three. You replace card two with card four and so on. This makes sense if you are shooting something that fills cards and you want the images to be sequential on the cards.
Not normally the way I would want it to happen and I wish they gave you more choices but that's the way it is.
05-14-2016, 01:56 PM   #7
BigMackCam's Avatar
In the hope that Ricoh is watching / listening, this bugs me too on my K-3 & K-3II
05-14-2016, 02:17 PM   #8
But regardless they could still have a setting that reads "sequential 2 1", instead of just the sequential 1 2.
05-14-2016, 02:52 PM   #9
jatrax's Avatar
Yep, no question. I just said I could finally see the logic, not that I agreed with it.
05-14-2016, 03:25 PM   #10
Tan68's Avatar
I think this is a good way for it to work :^|
Options are always nice, of course, but what real benefits would there be to write 2>1 versus the current 1>2 ?
Your description helps me understand how the system works and I know to go ahead and pull the full card in 1 while 2 will continue to fill.
05-14-2016, 03:27 PM   #11
QuoteOriginally posted by Tan68 Quote
If you happen to put in a blank card that you want to write files to for a single shoot, rather than the existing card.
05-14-2016, 03:40 PM   #12
jatrax's Avatar
+1. On the k-3 I rarely filled a card so having the camera occasionally record on card 2 when I thought it was on card 1 was disconcerting. The reality was that I never used card 2, it was just a card holder spot for a spare card. Now that I am actually filling cards I understand what is happening but an option to only use card 1 or card 2 or change the order would be welcome.
Anyway, a rather minor quibble on an otherwise excellent camera. If it's all we have to complain about, Ricoh did a good job.
05-14-2016, 03:51 PM   #13
Tan68's Avatar
i see
05-14-2016, 04:33 PM   #14
WPRESTO's Avatar
Question that popped into my mind, a situation that might arise. Suppose you are shooting, fill the card in slot #1, camera starts recording to card in slot #2 and builds up a significant quantity there. You want to continue recording on that card BUT ALSO anticipate more upcoming image files than will fit so you want to replace the full card with a blank one. DO you: 1) put the blank card in slot #1 and the camera will continue filing to the card in slot #2 then switch; OR 2) move the card from slot #2 into slot #1 and insert the blank card in slot #2 because the camera will revert to slot #1 when possible, so it will complete the filling of the re-positioned card then go to the blank card in slot #2. I'd be inclined to think the camera would follow the second option = always file to slot #1 if the card there has unused memory space.
05-14-2016, 05:42 PM   #15
That is the way I understand it as well. It would be nice if there were were also the option to "write to 'x' if empty else 'y'".
dslr, full frame, full-frame, k-1, k1, pentax k-1
To K1 or not K1 - that is the question? interested_observer Pentax K-1 78 07-15-2017 03:58 PM
Pentax HQ visit and K1 shipping news BrAtClIF Pentax News and Rumors 42 05-21-2016 02:54 AM
Some Old Guy K1 Questions? Rupert Pentax K-1 65 03-14-2016 04:28 PM
K1 Beta Tester ansering questions on Photography Reddit interested_observer Pentax K-1 3 02-18-2016 09:30 AM
silly question about HSM and K1*0D's OniFactor Pentax DSLR Discussion 10 01-31-2008 04:06 PM
All times are GMT -7. The time now is 01:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
