Originally posted by Barry Pearson I'm now confused! What I really want is to make it totally impossible on my K-1 ever to change the selected AF point or to move the AF area. I want everything always to remain centralised - that is how I shoot. But my camera keeps ending up in a mode where the 4-way controller changes the position of the selected AF point. I want to avoid that possibility. I can't work out whether C-20 achieves what I want? I simply don't understand what the words in the menu are trying to tell me. Help?!
Ah ah... that was exactly my problem!!!
1) AF selection: it looks like changing AF takes precedence over changing drive mode or white balance, and in some ways that can make sense. If you shoot in AFC for tacking moving subjects, you may have your WB fixed (for instance daylight), and change the drive mode directly with the top dial and change AF directly with the 4 ways buttons. That would be the use case for wildlife photo tracking for instance. ... I found a direct way to program the K1 for AFC tracking: I saved TAV 1/500th f8 + AFC multipoint modes in each of the USER1, USER2, USER3, USER4, USER5 modes, so that the AFC modes are changed which each USER mode, but the 4 ways buttons remain fixed to change the WB and drive mode. You can even use USER1,2,3,4,5 in combination with the top right dial.
You can also go back to single point AF in which case the 4 button controller goes back to WB and drive mode settings.
2) Manual mode: if you want to use the camera full manual: left dial set to M, top right dial set to ISO => basically, you can change aperture, shutter speed and iso with 3 wheels (like full manual film camera) and see the 3 settings in the small top lcd display.
So, yeah, every user has to figure how to use this thing.
Originally posted by Tjompen1968 Ok, now I understand the problem. That is quite unfortunate. An extra setting for disabling buttons would be useful.
I found a way around (read above). What I thought could be done (for people having a big thumb) is to set the "OK" button to confirm the AF selection mode (going back to WB+drive mode selection).
