05-20-2016, 11:25 AM   #1
volosong's Avatar
Number of exposures on different SD card sizes
By way of a followup to: https://www.pentaxforums.com/forums/190-pentax-k-1/320193-sd-card-capacity.html
Since the manual does not indicate how many shots one can acquire per card, as in past manuals, I thought I'd post it in case anyone is wondering.
Based on camera set on RAW+ with DNG exposures going to the SD card in slot 1 and JPEG "L" *** to the SD card in slot 2. Set to force Full Frame, even if a APS-C lens is mounted.
Cards "tested":
SanDisk Extreme SDHC 16GB, 45MB/s
SanDisk Extreme PLUS HDHC 32Gb, 80MB/s and 90MB/s
SanDisk Extreme PRO HDXC 64GB, 95MB/s
Two identical cards loaded into the body and immediately formatted. Then "INFO" to read exposure capacities.
16GB - 200 DNG, 696 JPG
32GB - 401 DNG, 1304 JPG
64GB - 803 DNG, 2782 JPG
05-20-2016, 11:38 AM   #2
Tjompen1968's Avatar
QuoteOriginally posted by volosong Quote
Based on camera set on RAW+ with DNG exposures going to the SD card in slot 1 and JPEG "L" *** to the SD card in slot 2. Set to force Full Frame, even in an APS-C lens is mounted.
Cards "tested":
These numbers only corresponds to what the camera estimates when it is empty. When you start shooting you will be able to fit many more images depending on the subjects you shoot.
But good to know the minimum limit.
05-20-2016, 11:44 AM   #3
jatrax's Avatar
Numbers will also vary based on the subject and shooting parameters. Might be why they do not put a hard number in the manual any more.
But to confirm, my 32gb cards all report 401 images available for DNG. Have not tried any other size yet.
05-21-2016, 05:54 AM   #4
Thanks for this info!
05-21-2016, 08:53 AM   #5
jatrax's Avatar
16GB - 200 DNG, 696 JPG 32GB - 401 DNG, 1304 JPG 64GB - 803 DNG, 2782 JPG
Just checked my 16gb and 64gb cards and I can confirm the exact same numbers. So I think the camera is just providing a generic estimate based on the formatted capacity of the card.
The actual number of frames that can be recorded on a card will vary quite a bit depending on the actual images being shot.
card, dng, dslr, full frame, full-frame, jpg, k-1, k1, pentax k-1, sandisk, sd, sd card, slot
camera taking different exposures on its own adjustment Pentax K-5 2 05-02-2015 09:52 AM
Number of raw files on sd card neostyles Non-Pentax Cameras: Canon, Nikon, etc. 2 09-29-2014 05:46 PM
Number of exposures on a K-5? ronpyke Pentax K-5 2 06-08-2011 07:35 AM
Number of exposures on my K10d? Larsenio Troubleshooting and Beginner Help 3 07-21-2010 05:15 PM
Number of PEFs on a SD card Arpe Photographic Technique 11 11-17-2008 04:52 PM
All times are GMT -7. The time now is 12:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
