05-20-2016, 11:44 AM   #1
volosong's Avatar
What is the proper procedure when using M and A zooms?
I have a couple of older zooms that I have enjoyed using for literally 'decades'. They've been on the shelf since my *istDS days, but with the Full Frame K-1, I've dusted them off and it is time to start playing with them again. As we all know, as soon as you mount a manual zoom, the body says to you, "Okay dummy. I see you're using an ancient, legacy lens. What focal length is it?"
What value should I use for a manual zoom? And what ramifications are there by specifying an incorrect focal length for a particular shot? Will it be that the shake reduction is off a bit, or something else?
Would I select any focal length initially, compose my shot, set my exposure, then take a look to see where the focal length the lens lands and go through the menu to re-set it? That seems like a lot of 'work'. Okay for static scenes, but if there is any motion involved, the shot will be long gone by the time I'm ready to press the shutter.
05-20-2016, 11:54 AM   #2
savoche's Avatar
I think the common view is to set it to the shortest FL. That way you won't have the SR over-compensate your movements. Of course, you won't get as good a stabilisation at the long end as you could have had.
Another strategy could be to dial in the longest FL, and switch off SR if you go wider. That way you get the best possible stabilisation at the long end (where you probably need it the most), but nothing at shorter focal lengths.
05-20-2016, 11:56 AM   #3
jatrax's Avatar
That is one reason I do not use legacy zooms. Legacy primes, yes, zooms, no.
The focal length question will impact two things:
1) The focal length input is recorded in the EXIF and is therefore a part of the file information. This might not matter much and in any case there is little that can be done about it.
2) It also sets the focal length for the shake reduction. There are a number of theories on this. Some folks say to just set it in the middle, others set it to the short end, some say set it to the most used focal length. At faster shutter speeds this might not make that much difference. At slow ones there might be some impact, I've never noticed any difference to be honest. YMMV.
05-20-2016, 11:57 AM   #4
QuoteOriginally posted by volosong Quote
See this thread and the links in it:
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/253121-manual-focus-...h-setting.html
Basically you have 4 options:
1. set it to the lowest focal length and forget about it (at longer FLs, you may get sub-optimal stabilization, but no blur)
2. set it to the focal length you use most frequently (results at shorter FLs may be slightly blurred)
3. change it as you zoom
4. set it somewhere in between (could potentially yield better results at longer FLs at the expense of over-compensation at shorter FLs)
On the K-1, you can put the focal length setting in the control panel, so the procedure would be info -> e-dial -> done! I put mine in the bottom-right:
05-20-2016, 11:57 AM   #5
jatrax's Avatar
QuoteOriginally posted by savoche Quote
And here is another theory
05-20-2016, 12:04 PM   #6
ScooterMaxi Jim's Avatar
It really depends on how you'll be using the lens. My 100-300/4 lens is almost exclusively shot at 250-300, so I feel comfortable at 250. No other lens I own reports that length, so that helps, as well. As for my 35-105/3.5, it is generally used as a portrait lens (for which it is very good), and mostly from 65-105 (where it is optically very strong). Set at 65 - another length not reported by another lens. Overall, setting slightly conservatively is the best advice, but the over-correction of shooting a bit wider than the setting can be overstated. Ballpark is usually good enough.
05-20-2016, 12:18 PM   #7
This could have been something for the new function dial, or whatever it's called.
05-20-2016, 05:25 PM   #8
Not a Number's Avatar
Do the user modes store MF focal length? If they do you could set FL ranges in the modes and switch it that way.
05-21-2016, 03:35 AM   #9
i5_david's Avatar
Interesting concepts. Thanks for sharing, friends. Good ideas in here.
Never gave it too much thought
dslr, full frame, full-frame, k-1, k1, length, lens, pentax k-1, shot, time
Question What is the "time out" time when using the forum? jpzk Site Suggestions and Help 2 05-01-2013 07:21 PM
What is the function difference of using stabilizer and rig liukaitc Video and Pentax HDSLRs 3 08-12-2011 12:54 PM
what is focal length when using extension tubes. katanaismybike Photographic Technique 9 07-17-2010 01:44 PM
What is the proper hotshoe adapter to use for a K20D with a Metz 58-AF 1 flash? aweir Flashes, Lighting, and Studio 11 06-25-2009 02:34 PM
Using a cable release and MLU on a K10D-procedure? macdaddy Photographic Technique 6 11-26-2007 05:35 PM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
