05-26-2016, 06:26 PM   #46
rod_grant's Avatar
QuoteOriginally posted by Quartermaster James Quote
I'll keep that in mind. Thanks!
He probably meant sled races!
05-26-2016, 07:11 PM   #47
Sandy Hancock's Avatar
K-1 files seem to pretty ISO invariant. I often shoot two or three EV's lower ISO than I probably should and deliberately underexpose if I need the shutter speed or depth of field. I'd much rather push two stops than be half a stop blown in the highlights.
So for spontaneous stuff I often stay at 100-400 outdoors, with whatever other settings I want, and work around it later. Live music in poorly lit venues I might go to 1600 or even 6400.
05-27-2016, 01:19 PM   #48
I did a handheld ISO test shoot. Yes , should have been on a tripod but I was lazy and this way I figured I could also do some SR testing..
iso_sr Photo Gallery by jl2 at pbase.com
05-27-2016, 01:38 PM   #49
QuoteOriginally posted by janneman Quote
I don't see ISO noted for whichever image
Am I overlooking it ?
+ quite nice shed for your gardening tools.
05-27-2016, 03:09 PM   #50
QuoteOriginally posted by Tan68 Quote
should be in text below the pictures (not the crops)
05-30-2016, 06:49 PM   #51
Shanti's Avatar
With K1 I can use 1600-2000 for birds if needed & still clean..even 5000-10000 has worked for some(web size of course)..amazed at the low noise on K1..need high ISO at times as must keep shutter high-- 1600 sec or more with DFA 150-450..SR don't really help at that length(450) i find
dslr, full frame, full-frame, iso, k-1, k1, pentax k-1
What does an Amazon acceptable grade LTD lens look like? robtcorl Pentax SLR Lens Discussion 3 12-26-2014 08:00 PM
How much play is acceptable on a new lens? MeowMix Pentax SLR Lens Discussion 4 12-24-2014 06:13 AM
cosmetic lens repairs acceptable? slip Pentax SLR Lens Discussion 7 11-18-2012 08:47 AM
People Acceptable? Rupert Photo Critique 2 07-23-2011 02:24 PM
Is this acceptable qksilver Pentax SLR Lens Discussion 12 05-23-2008 07:24 AM
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
