06-01-2016, 01:37 AM   #1
MichaelErlewine's Avatar
Does the Pentax K1 Allow Wireless Remotes to Operate Behind the Camera
Does the Pentax K1 Allow Wireless Remotes to Operate Behind the Camera. I want to trigger the shutter from behind the camera, not in front. Some wireless remotes only work from the front. Which ones, if any, work from the rear? Does the K1 have both front and back IF sensors?
06-01-2016, 01:58 AM   #2
Tas
QuoteOriginally posted by MichaelErlewine Quote
Yes.
I was using a Pentax wireless remote from behind the K-1 yesterday.
Actually, all four Pentax DSLR's I've had have worked from both front and back.
Tas
06-01-2016, 02:08 AM   #3
Moderator PEG Judges
Kerrowdown's Avatar
Aye nae bother, the standard remote (Remote Control F) from my K10D days works just fine.
06-01-2016, 03:50 AM - 1 Like   #4
Yes. They are visible here, and very effective.
[K-1 manual]
06-01-2016, 05:44 AM   #5
QuoteOriginally posted by Tas Quote
Yes.
Tas
Just to add to this. The K-30 only works from in front of the camera.
06-01-2016, 05:44 AM - 1 Like   #6
Wheatfield's Avatar
Page 7 of your manual shows where the remote control receivers are located.
06-01-2016, 02:04 PM   #7
Tas
QuoteOriginally posted by Mistlefoot Quote
Thanks for adding that, I've used the K10D, K7 and K5 before the K-1 so it could be that some of the other models are like the K30 and only work with IR remote from the front.
Tas
06-01-2016, 04:08 PM   #8
The K-20D, K-7, K-5 and K-3 all have front and back IR sensors, so IR remotes will work front and back on all of those.
K-x and K200D lack that feature though, as do the K-30, K-50 and K-S2. Front and back IR seems to be a 'flagship' feature.
06-24-2017, 11:44 AM   #9
Any problems using the IR remote in daylight? Also, what IR remote do you recommend?
07-10-2017, 12:25 PM   #10
QuoteOriginally posted by wings Quote
No problems here.
I actually use an app on my Samsung smartphone, which has an IR blaster built in.
07-10-2017, 02:34 PM   #11
kooks's Avatar
You can even use your cellphone as an IP remote if you have one with an IP port and download the app.. its actually pretty usable.
07-12-2017, 02:18 PM   #12
For pocket use, the Pentax O-RC1 is a cute little remote. It's about the size of a key FOB (about 1 x 2 x 0.25 inches), and has three buttons, two of which work with the K-1. One is used for focus, and the second for shutter trip. I believe it's advertised as water resistant though I wouldn't want to run it through the washing machine by accident. It also works with time exposures (shutter stays open as long as the shutter button is pressed). The literature says the battery isn't replaceable but there are screws on the back, so it could be possible (haven't tested the theory myself). Check B&H - reasonably priced. I used it in a dark environment and got about 15 feet - that distance would probably diminish in brighter lighted areas.
camera, dslr, front, full frame, full-frame, k-1, k1, pentax, pentax k-1, pentax k1, remotes
Wireless password for the Pentax-K1? senju Pentax K-1 9 10-25-2017 08:38 AM
To K1 or not K1 - that is the question? interested_observer Pentax K-1 78 07-15-2017 03:58 PM
Does the Pentax K1 have EFSC MichaelErlewine Pentax DSLR Discussion 12 05-23-2016 06:31 AM
wireless remotes for the Q. barondla Pentax Q 23 03-22-2013 05:24 AM
Does the ZX-50 operate without film? clockwork247 Pentax Film SLR Discussion 9 01-16-2011 10:25 PM
All times are GMT -7. The time now is 07:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
