06-05-2016, 11:12 AM   #31
RockvilleBob's Avatar
Thanks for the post Steve - I will try again tomorrow but my virus scanner seems to dislike something about ExifTool
06-05-2016, 02:19 PM   #32
QuoteOriginally posted by Schraubstock Quote
Adam, I am afraid, as mentioned above the new Pentax lenses are not reliably listed.
Updates are released frequently- are you using v10.17 or newer? We use exiftool on the forum and it's able to recognize the latest Pentax lenses
I'm not sure if the windows gui comes with the latest version of exiftool. I've only used the command line version.
06-05-2016, 07:55 PM   #33
Otis Memorial Pentaxian
No, it doesn't. You download the two programs separately. The GUI simply wraps standard ExifTool calls and parses the output into the display tables. It is sort of cool that way since you can update your ExifTool and the GUI is remains clueless.
06-05-2016, 10:33 PM   #34
clackers's Avatar
Ah, Google - never heard of it. Give me a break.
No it isn't, it is not new to me. But unfortunately it does not work on my computer. The data just flashes on screen for a few milliseconds.
Remember you can always pipe the output to a textfile with the -echo option so you can examine at your leisure later on in Notepad or whatever.
06-05-2016, 10:57 PM   #35
The "flash and its gone" behavior is what happens when one drops the file directly on the exe. The solution is to create a shortcut to the exe and drop onto it. Either that or do as you suggested from the command line.
06-06-2016, 08:52 AM   #36
exiftool is used in tons of GUI applications on different platforms. One might be using it and not realizing it.
It can run in Lr as a plugin via the LensTagger plugin. (And some others; don't recall which.)
The Mac App Store has a ton of GUI applications that I believe make use of it, although few allow editing with it. The best I've seen is Exif Editor, Exif Editor
One of the best Mac applications for manipulating exif metadata is Graphic Converter, which uses exiftool and has lots of metadata manipulations built in. Just upgraded to v10, it now also does face tagging in an XMP compliant way with frames to locate the face in the image.
06-06-2016, 01:52 PM   #37
emalvick's Avatar
ExifTool is definitely the best most complete utility there is for reading all metadata. If you can't read it, just wait until next week... That has been my finding. Phil Harvey updates that program so quickly.
If you actually find it isn't doing something you expect, it's worth corresponding with him to help get what you need implemented added. New lens, new camera features, etc.
The GUI has been the most complete software for viewing the data only because as someone mentioned earlier, it can show all the EXIF, XMP, IPTC data rather than being limited to some finite group of tags.
06-06-2016, 11:57 PM   #38
Thanks emalvick, I will try to contact Phil H. because the new Pentax lenses do not show up under the "Workspace" heading of the GUI and that is the place where I try to look because it condenses pretty well everything I want to know on the fly.
Thanks again
06-07-2016, 12:06 AM   #39
No point doing that. Phil is not the author of the GUI, nor does he play any role in maintaining it. The GUI has been abandoned by its author.
FWIW, I find the older version of the GUI (v4) to be simpler and more usable than the current version (v5).
06-07-2016, 05:49 AM   #40
I know I realised this too late myself was too late to correcting it. Fingers type faster than brain is geared up
camera, data, dslr, exif, full frame, full-frame, k-1, k1, lens, pentax, pentax k-1, reader, service
EXIF Viewer bcorson Pentax K-30 & K-50 4 06-02-2013 12:15 PM
EXIF viewer for those interested (browser) slip Digital Processing, Software, and Printing 3 04-07-2011 08:18 PM
right click exif viewer with windows 7? NaClH2O Digital Processing, Software, and Printing 2 11-17-2010 02:34 PM
Which EXIF viewer works with Vista? Heinrich Lohmann Digital Processing, Software, and Printing 13 11-24-2008 12:27 AM
EXIF Viewer plugin (firefox) gawan Photographic Technique 9 03-06-2008 02:05 PM
All times are GMT -7. The time now is 01:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
