Originally posted by Schraubstock An extra thank you to beholder who's retort was particularly useful as I had never heard of "GOOGLE" before. Now when forum members ask questions here we can just tell them "GOOGLE" it. Problem solved. Cool
Google is our friend and it is often obvious when a user prefers to have forum members do the work for them. Other times, the Google results are not very useful and forum members experience can help clear the fog. I believe your question/rant falls into the latter category and thought the response was a little abrupt. That being said, the short answer regarding comprehensive EXIF support for the K-1 is simply ExifTool. As for support from Ricoh/Pentax, they expose the stuff they believe is useful to end users in the PDCU in the image properties box.
Originally posted by Schraubstock Thanks for that. I had run this years ago and struck some compatibility problems with it and never looked at it again. Given it another go and it does work but Pentax's new lenses 28-105, 15-30 and 150-450 are not listed reliably. Other third party glass is listed where info is available.
'8 59' = HD PENTAX-D FA 150-450mm F4.5-5.6 ED DC AW
'8 61' = HD PENTAX-D FA 28-105mm F3.5-5.6 ED DC WR
'8 63' = HD PENTAX-D FA 15-30mm F2.8 ED SDM WR
Are your lenses reporting codes other than these? The result would be listed under the "Maker" tab in ExifToolGUI as "LensType". Pentax (as with other makers) does not write textual lens information to exif:LensModel or exif:LensInfo. If you need a lens name and info written to those fields, ExifToolGUI has a neat feature under "Modify" on the menu bar called, "EXIF:LensInfo from makernotes". Using that feature will read the numeric codes from the makernotes and write the text from ExifTools lens name table into the standard EXIF. I use the feature all the time for lenses that Lightroom is too dumb to ferret out for display purposes.
The list of Pentax-compatible lenses (K
AF, K
AF2, and K
AF3) supported by ExifTool is extensive (see link below).
ExifTool:Pentax LensType Table
Unfortunately it does not. Pentax cameras have some unique advanced functions, among others PixS, (as well it would be nice to have identification of focus points and similar stuff) and all of these are unsupported.
PixS is supported in ExifTool as is focus point information.
Edit: To be fair, ferreting out information from the Pentax maker notes may be frustrating. For example, the focus point information may be found in two different locations with the same being true for LensType. Which location or both may depend on the camera model. In defense of Pentax, the metadata written to the makernotes is
not intended for end users. The format is proprietary with the intent of providing tool support and clues for service diagnostics. From what I can tell, the most recent version of PDCU (5.5.1) does a very good job of exposing the available metadata of practical importance to the end user.
