06-08-2016, 04:34 AM   #16
Went back to the dealer, appears more reports poping up on the www Pentax also said it was a fault.
06-08-2016, 06:22 AM   #17
i83N's Avatar
Battery grip on camera?
06-11-2016, 07:49 AM   #18
I've got the same problem ..... 3 days in Polish service center solved the problem .... it is hardware problem .
06-11-2016, 10:21 AM   #19
UncleVanya's Avatar
This is becoming a bit of a common refrain...
06-11-2016, 11:27 AM   #20
QuoteOriginally posted by ukspeedtraps Quote
Tonight turned on the camera and it was refusing to come out of manual mode. Even a rest and nothing.
I see there is a video in bugs thread but no reply.
Anyone seen this before have I done something wrong, before I go to the dealer..
sounds like the ribbon cable from the top cover isnt seated to the body
---------- Post added 06-11-16 at 02:30 PM ----------
QuoteOriginally posted by managger Quote
Dear colleagues,
This bug is not a software issue.
One guy from St-Petersburg, Russia, had this problem in the end of May and already solved it.
Less than a week in the service and he is happy again.
Official russian serviceman sad that some contact was lost. Repair is not long and complex, but it is hardware issue and you need to go to the service.
I think it will be often case, so do not lose the time in discussions
It is most like the ribbon cable from the top cable is not seated correctly to the body. I t is an easy fix
06-12-2016, 11:27 AM   #21
any luck
06-12-2016, 12:33 PM   #22
slip's Avatar
Also, since it sounds like this might be a software bug, try doing a battery pull while the camera is on, or reset the settings.
this is very common in a lot of electronics, especially cell phones.
06-12-2016, 12:45 PM   #23
no it is a simple fix, but if it is under warranted send it in
06-13-2016, 12:58 PM   #24
Same problem here .
I'm gonna have to take it back to the store. Sad.
06-13-2016, 01:23 PM   #25
QuoteOriginally posted by niceshot Quote
any luck
Yes, SRS sent a new K-1 on Saturday, fantastic service..
06-13-2016, 01:23 PM   #26
LinnBJ's Avatar
Had the same failure with my 1 month old K1 today.
06-13-2016, 02:10 PM   #27
UncleVanya's Avatar
I'm glad this is an easy fix... curious to see how the fix holds up over time. I hope it is a long term fix not a band-aid. Does anyone have any info from their repair that indicated the likelihood of a repeat issue.
06-15-2016, 10:40 AM   #28
LinnBJ's Avatar
Most happy to tell you my K1 was repaired in less than 1 hour after I delivered it for service! I delivered it at 1:30 today, and got the message that it was fixed and ready to be picked up at 2:24 . I am most grateful for the kind and quick service I got from Norwegian FOVI and Camera & Videoteknikk
Read more at: https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/323158-k...#ixzz4Bfeuc8br
06-15-2016, 01:31 PM   #29
UncleVanya's Avatar
QuoteOriginally posted by LinnBJ Quote
What fantastic service!
06-15-2016, 03:53 PM   #30
A repair turnaround of 1 hour does beg the question - if the issue can be so quickly fixed, it seems like a very simple flaw that might even be repairable by end-users ...
Of course, one could also note that if the flaw is indeed a very simple one, it shouldn't exist in the first place, if the camera was designed (or assembled) properly.
cable, dslr, full frame, full-frame, issue, k-1, k1, mode, pentax k-1, ribbon, service
How to do a better manual focus in K1 kinkindoll Pentax K-1 16 05-07-2016 02:26 AM
Pentax K-3, Manual Mode won't switch to Av, Bulb, but stays in M Mode scotman55 Troubleshooting and Beginner Help 3 12-05-2015 08:39 AM
K-x stuck in Manual Focus mode... Alizarine Troubleshooting and Beginner Help 13 12-15-2013 10:27 PM
Pentax K100D stuck in manual mode LloydTifflin65 Pentax DSLR Discussion 2 04-20-2011 10:04 PM
Digital concepts 952AF/PEN flash stuck in manual mode? murphysf Flashes, Lighting, and Studio 3 01-02-2011 10:50 AM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
