06-08-2016, 11:24 AM   #1
Timd's Avatar
FF vs crop mode
I'm keen to understand whether there are any IQ differences between using crop mode or cropping a FF photo down to the same size. I presume the advantage of crop mode is the smaller file size.
06-08-2016, 11:40 AM   #2
jatrax's Avatar
And not vignetting with da lenses.
06-08-2016, 11:40 AM - 1 Like   #3
The only avantages are:
- the file size
- the burst rate
- the availability of the lens correction if you use jped and a DA lens with no in-body lens profile for FF (same applies if your software doesn't support your lens for FF)
- the metering is done only on the crop area (no impact except if your lens is vignetting A LOT)
---------- Post added 06-08-16 at 08:41 PM ----------
You'll get rid of vignetting while croping in post as well.
06-08-2016, 11:55 AM   #4
UncleVanya's Avatar
QuoteOriginally posted by Glorfindelrb Quote
No viewfinder vignetting? I'm asking I don't know.
06-08-2016, 03:07 PM   #5
jatrax's Avatar
And what does that have to do with crop mode on the camera?
06-08-2016, 03:16 PM   #6
The question was the differences between FF mode then crop to APS or crop mode directly.
You get viewfinder vignetting in both solution. You have an indicator of the APS area in crop mode but you have to stick with it.
crop, da, dslr, ff, ff vs crop, full frame, full-frame, k-1, k1, lens, mode, pentax k-1, post, size
FF mode - DA15 - crop factors & crop sizes acoufap Pentax K-1 6 05-09-2016 05:52 PM
How does a FF work in crop mode? Albermarle Pentax Full Frame 54 12-29-2015 11:28 AM
FF in crop mode for astro Conqueror Pentax Full Frame 6 09-15-2015 10:36 AM
(un-)importance of crop mode for FF ?!? Arne Bo Pentax Full Frame 54 03-21-2015 02:11 PM
Crop Vs FF lguckert79 General Photography 3 07-29-2014 03:02 PM
All times are GMT -7. The time now is 09:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
