Show Printable Version 11 Likes Search this Thread
06-26-2016, 11:34 PM - 1 Like   #31
QuoteOriginally posted by nater Quote
Does anyone have any experience with pre-HSM Sigma EX and EX DG lenses on the K-1?
Yes. Usually, they work without problems. I've got two - a 12-24 and a 24-70, both sporting a diaphragm ring (lockable in 'A' position).
You can check yourself - the bayonet ring on the "affected" lenses, that is those with the mechanical problem, ist really huge. Check the image above posted by noelpolar, here you can see the bayonet contacts in relation to the ring's diameter.
Older Sigma lenses used normal-sized bayonet rings (at least the ones I know of), so there's no problem.
The firmware problem (causing camera body lockups) might be related to SDM/HSM lenses only, since the KAF3 protocol clearly is different from the KAF protocol.
From all the Sigma glass I've got only one is problematically, that's the 70-200/2.8 APO EX DG HSM Macro II, and that one's currently being serviced by Sigma.
Last edited by funktionsfrei; 06-26-2016 at 11:35 PM. Reason: removed double quote
06-27-2016, 04:37 AM   #32
Erd§'s Avatar
I can confirm that there is no issue with mounting the 100-300mm f4 EX DG on the K-1, and it works as expected.
06-27-2016, 08:38 AM   #33
QuoteOriginally posted by funktionsfrei Quote
It was being serviced - today I got it back -- for free!
06-27-2016, 09:20 AM   #34
ahw
Anyone see a problem with just putting a thin strip of tape over the part of the K-1 body that gets scratched?
06-27-2016, 10:51 AM   #35
Won't help. If there is not enough clearance between lens and camera body, inserting something between them does not improve anything.
The lens will press against the "thin strip of tape" resulting in additional shearing on the lens mount.
No, I would not consider this a good idea.
06-27-2016, 11:24 AM   #36
Thank you for confirming what I had inferred/expected. I'll be very happy if my efforts to avoid owning any HSM lenses work out well in the end with regards to the K-1.
06-28-2016, 04:50 AM   #37
jackassp's Avatar
I sent off my 35/1.4 Art, and 85mm/1.4 DG HSM, and got them both back within 1 week (Australia). Problem solved, and both work better on the K-1 than they ever did on the K-3.
Now waiting for 24-70 and 50-500 to come back.
JP
damage, dslr, full frame, full-frame, k-1, k1, lens, pentax k-1, question, sigma, sigma damage
HD 1.4xTC damage to lens? UserAccessDenied Pentax SLR Lens Discussion 7 05-11-2016 08:26 AM
For Sale - Sold: Sigma 50mm f1:2.8 K-A Mount 1:1 Macro Manual Focus Lens $85 shipped to US Archimedes the Dog Sold Items 7 11-28-2015 09:46 AM
Excessive wear or damage to tripod socket? bwDraco Pentax K-3 & K-3 II 15 07-14-2015 05:53 AM
Slight damage to K-30, plastic cover for pop-up flash, anywhere to get a new one? JesterPrime Pentax DSLR Discussion 16 02-02-2013 02:24 PM
Sigma extends warranty to cover Hurricane damage from Sandy interested_observer Pentax SLR Lens Discussion 2 11-09-2012 08:36 AM
All times are GMT -7. The time now is 05:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
