06-12-2016, 03:52 PM   #31
Sandy Hancock's Avatar
QuoteOriginally posted by melander Quote
even tho its not the best landscape lens anymore due to vignetting. Macro works great and I still love my DA 35 macro ltd
Absolutely.
Don't get me wrong - it's still a fantastic, even uniquely wonderful lens.
06-12-2016, 11:03 PM - 1 Like   #32
I have used the 35mm Ltd lens a few times recently, with the Pentax K-1. My experience is the following: (a) Quite a lot of vignetting if you use the incorporated hood (b) a small amount of vignetting if not using the hood. I enclose a couple of photos to illustrate this. The waterfall was at f16 to reduced the shutter speed. The panoramic shot was two photos stitched and taken at f8. Both photos taken using a tripod. Neither have been corrected for vignetting, which is slightly noticeable, but not significant for me. The image quality seems excellent to me, across the frame. Regards, John
PENTAX K-1  Photo
06-13-2016, 02:36 AM   #33
RobA_Oz's Avatar
With the variations that people are showing here, I can't help wondering if we're seeing production tolerance differences or even production variants that are responsible for those differences. I'll run some tests on my own sample now, to see what it produces.
06-13-2016, 02:53 AM   #34
QuoteOriginally posted by johnmb Quote
It's a nice shot; the dense physical vignetting is only not a problem here because the corners are already dark. My test shots were designed to demonstrate the problem, this seems designed to hide it.
The overlap conveniently removes the vignetted corners of the right and left corners of the left and right image respectively. The vignetting in the remaining corners looks rather weird given the aspect ratio of the resultant stitch. You'd get a much better result in crop mode stitching four or five images in portrait orientation.
At the size they are posted it is impossible to say with certainly, but the edges look pretty fuzzy to me.
---------- Post added 13-06-16 at 07:27 PM ----------
QuoteOriginally posted by RobA_Oz Quote
I reckon the results in johnmb's post are entirely consistent with mine, for the reasons stated above. By all means do your own tests though
09-15-2016, 12:16 PM   #35
I've found that if crop to 24mp at 3:2 aspect ratio there's no obvious vignetting, thus getting a k-3 worth of pixels with the greater scope to push in post. Handy option to me.
corners, da35/2.8 macro, depth, depth of field, dslr, field, frame, full frame, full-frame, image, k-1, k1, length, lens, macro, pentax k-1, photos, post, production, shot, tests
DA35 2.8 limited - I can't believe nobody bid on this one.. K57XR Pentax SLR Lens Discussion 11 05-09-2015 11:48 AM
FA 31 limited vs DA35 Macro 2.8 limited peterjcb Pentax SLR Lens Discussion 19 05-07-2014 03:21 PM
For Sale - Sold: K100D Super, 18-55, DA21, FA28, DA35/2.8 macro, DA40, FA50/1.7. FA50/2.8 macro dgaies Sold Items 14 09-18-2011 03:46 AM
All times are GMT -7. The time now is 06:06 PM. | See also: NikonForums.com, part of our network of photo forums!
