Originally posted by MichaelErlewine However, it seems, aside from darkening and lightening, that what I see does not change, aperture-wise, meaning I don't see more or less of the depth-of-field in LiveView, but just a static view of the lens wide open. Is this the way it is? Is there no way, with a coupled lens, to see the aperture change the DOF in Live-View, AND when I magnify, same deal. Magnified, I have to TRY to focus on the lens wide-open, even if I have it set to f/16 and need to see the depth of field in order to focus properly.
Live view does
not represent the final photo. Live view is merely an aid to help you compose and focus. You can use the DoF preview (you may have to configure it to a custom button), which will show you the DoF/bokeh of the final image. But Live view ignores shutter speed and ISO when it displays the image, and most of the time it uses the wrong aperture. This is why using Zoom is helpful - it opens the lens' aperture to maximum, for easier manual focus. And DoF preview button shows the actual chosen aperture.
Simply put, live view is not an accurate representation of the final photo with your chosen settings. It is merely a guide. Just like OVF doesn't show you the same brightness as the final photo, because it cannot compensate for shutter speed and ISO choices.
Both are valuable tools and you have to learn which buttons to press to get the information you need, to get the photo you want. Focus peaking and digital zoom are the most important, and DoF preview helps as well. With practice, you will intuitively understand these things and will be able to "imagine" what the final photo will look better than what the camera shows you.
