06-20-2016, 05:53 AM   #1
jcdoss's Avatar
K-1, LV in low light
Question. I was using the K-1 in a museum of sorts over the weekend, and trying to use LV to get precise manual focus. So the scenes were typically dark backgrounds with brightly lit subjects. The problem I had was, the LV auto-adjusts depending on the scene, which is OK, except when I tried to magnify something that was brightly lit, it would blow it out big time, and I couldn't focus on it at all. Anyone experienced this, and if so has anyone figured a work-around?
06-20-2016, 05:59 AM   #2
I have the same problem with the K5, and the best solution I have found so far is to use center weighted light metering. That will work as long as the object is large enough to cover the center.
06-20-2016, 06:49 AM   #3
Tjompen1968's Avatar
Have you tried other exposure modes? They behave differently.
dslr, focus, full frame, full-frame, k-1, k1, lv, pentax k-1
Weekly Challenge Pentax K-1 Weekly Challenge #2 "Low Light" Adam Weekly Photo Challenges 18 06-29-2016 06:21 PM
Machinery Low light K-1 Performance Peter Nutkins Post Your Photos! 10 05-03-2016 10:54 PM
K-3 doesn't focus in low light conditions zoolander Troubleshooting and Beginner Help 10 10-28-2014 01:38 PM
K-5 flash metering in low-light blockamon Pentax K-5 5 11-29-2010 02:51 AM
K-X Autofocus in low light? planedriver Pentax DSLR Discussion 8 12-07-2009 10:42 AM
All times are GMT -7. The time now is 06:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
