06-21-2016, 10:12 AM - 1 Like   #1
What you could do with a K1 that you can't do without
Found this photographer's site Las Vegas Family Photographer | LJHolloway Photography.
Pretty amazing. Could be done with a Pentax K1 and fast tele lens, in suitable lighting, choice of background and colors.
06-21-2016, 10:52 AM   #2
Definitely some good shots there.
06-21-2016, 11:00 AM - 5 Likes   #4
Heie's Avatar
While it would take a bit more deliberation and a longer working distance, there is ABSOLUTELY no reason you can't do this with a Pentax crop and a sharp, capable prime such as the DFA 100 f/2.8 Macro WR or Samyang 135 F2 wide open. I've come pretty damn close a few times despite not going for that style.
Gorgeous work, but certifiably not exclusive to full frame.
And despite carrying the namesake to the technique, I find Brenizer to not be that good at it. The final quality of his images are quite pedestrian and frankly lackluster for someone of such unparalleled acclaim imo...
Ett Venter produces far more gorgeous Brenizers, and he is shooting with Fuji mirrorless...
-Heie
06-21-2016, 11:28 AM   #5
Oh yeah, I used to use a pano head, stitch panoramas, also for wide angle, it is cheaper but takes more time, in some cases you can do it, people can't wait for so long that you have to tweak for nodal point. Now I point and shot with the K1
06-21-2016, 11:30 AM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by Heie Quote
Yep...the technique may be used with most (all?) cameras, but is particularly useful for smaller than medium format.
06-21-2016, 11:49 AM - 1 Like   #7
-Heie
ABSOLUTELY!
What I find funny about people saying that "This is what FF can do" is that they never seem to realize that all that has also been done with crop as well. It's just that you happened to come across an example of it done with FF. If you are a bad photographer, FF is just going to help you make more expensive bad photographs, and lessons, study and practice will be far more effective than buying any gear to improve your work.
Look at what Damien Lovegrove Home - ProPhotoNut does with Fuji crop cameras, FF is definitely NOT the factor that matters when trying to do this work.
Don't get me wrong, I like having the option available should I ever find myself needing it, and anything that breaths life into Pentax's coffers is a plus as long as it doesn't come at the expense of the APS-c system.
06-21-2016, 11:53 AM - 7 Likes   #8
Fat Albert's Avatar
I can swing it around by its rear LCD screen, which I could NOT do with my K3 II. Pentax/Ricoh have made a winner!!!
06-21-2016, 11:59 AM   #9
QuoteOriginally posted by Qwntm Quote
Not the same, you have to look twice. Sounds like the persons saying that the same can be done without full frame haven't done much bokeh panorama if none at all. When you stitch images with a person included in the frame, you can't ask them to stop breathing and completely freeze their body for the time you're taken multiple shot with a smaller format camera. At least you have to fully include the person you are photographing in a single frame, or have issues to align images when stitching, which greatly limit how much effect you can achieve with a smaller format camera. Do a bokeh panorama with a small camera and redo on with a larger format, the subtle perspective effect that project the view of the observer on the subject is hard to achieve below full frame.
06-21-2016, 12:03 PM   #10
bertwert's Avatar
QuoteOriginally posted by Fat Albert Quote
06-21-2016, 12:13 PM - 1 Like   #11
Who said anything about stitching? Honestly I am not sure what you are saying.
At the two websites that were mentioned, I see nothing on either one of them that could not be done with a crop camera, 1 shot, and enlarged to 30x40 inch print.
I have full confidence that a bokeh panorama is as easy to achieve with a crop as it is with a FF. These examples are not panos, but they make the point:
D810, 20mm lens
K5IIs 15mm ltd
I know Chloe is further back in the crop shot, but look at DOF in the grass, it's about the same for each shot.
I will also add this example:
Canon 6D, 24-70L - Not a bokeh shot at all but a single FF frame cropped to pano aspect
K3II 55-300 Single APS-C frame cropped to pano format.
Not only was it difficult to see any difference between FF and APS-C in my tests, the FF 6D actually proved inferior in IQ to the APS-c. (And that was Canon's $1000 L glass vs. Pentax's Consumer grade $300 zoom)
06-21-2016, 12:31 PM   #12
macman24054's Avatar
As far as bokeh is concerned a FF is superior. With aps-c you have to use subject to background distance and subject to foreground distance to your advantage. There is a reason the DA* 50-135 is one of the most popular portrait lenses on the forum. The rendering from it's lens compression can be just as pleasing to the eye as FF bokeh. Jpeg straight out of my K-50.
PENTAX K-50  Photo
06-21-2016, 12:41 PM   #13
panoguy's Avatar
That is some great work, and I'm not partial to wedding photos (though I know you are, in a professional sense). Looks like Fuji medium-format to me.
06-21-2016, 12:50 PM   #14
Firstly, I am guessing that Holloway could create a LOT better photos with my K-5iis and 77mm, than I could with her 5D Mark iii and Canon EF 200mm f/2L. Talent trumps over equipment any day. I LOVE her work.
The K-1 and (pick your Pentax lens) could do well, but unfortunately has no real match for a Canon EF 200mm f/2L For me, it doesn’t matter that Pentax does not have a match for that combination, because even if they did, I would never have the $9,000.00 to pay for it anyway!
06-21-2016, 01:07 PM - 3 Likes   #15
Heie's Avatar
Sounds you like haven't if none at all
K-3, DA* 55 and 3 shots at F1.8 (haven't calculated the resulting equivalent FoV/aperture)
K-3, Sigma 85. 42 shots combined to make a calculated equivalent of 18mm f/0.7 (yes, 0.7):
QuoteOriginally posted by macman24054 Quote
Umm...
Bokeh is not a "sensor-size thing." It's a "lens thing"...
It's easier to create bokeh on larger sensors simply because the depth of field is inherently shallower (which logic then yields "more is out of focus" or "less is in focus" - which ever you prefer). Physics is kind of the law that way...
But despite depth of field being largely based on sensor-size, it is certainly not exclusively dictated by it.
Compression =/= bokeh.
K-3/K-5 IIs, DA* 55 for all of these:
K-3/K-5 IIs, FA 77 for all of these:
K-3, Sigma 85 for these
Compression has actually little to do with Bokeh as it's instead how an image is (or isn't) distorted based on where features within an image fall in relation to each other (i.e. spatial distance between ears, nose, and mouth). But bokeh is 100% possible without telephoto compression...
K-3, Sigma 18-35 @ 18mm
The reason the 50-135 is one of the most popular portrait lenses is because it is the APS-C equivalent to the "standard" 70-200mm on FF.
It's frustrating the amount of people that contribute to discussions such as this and attempt to pass themselves off as definitive expertise on a subject when they (apparently completely unknowingly) do not know what they are talking about. Nothing but proliferating misinformation.
Incredibly irritating...
QuoteOriginally posted by panoguy Quote
Yea I'm in love with his style of Brenizers. They're just so clean and perfect Fuji X-T1 is what he uses after ditching his Nikon FF gear. As a lover of primes I tried to get him to consider Pentax and the limiteds, but Fuji already had their hooks sunk in him haha
And I'm "partial" to them because for some reason I enjoy the chaos and photojournalism aspect of it
-HeieAdd to Anti-Banner
aps-c, background, blur, blurr, bokeh, da*, dof, dslr, focus, foot, frame, full frame, full-frame, k-1, k-3, k1, lens, lenses, pentax k-1, people, perspective, sensor, time
Your vehicle: what do you have, why do you like it, and what do you not like? Auzzie-Phoenix General Talk 2040 01-14-2020 01:59 PM
People It's not about what you have but rather what you can do with it aleonx3 Post Your Photos! 4 02-19-2016 08:52 AM
That photography thing you do and don't do LeDave General Photography 31 02-07-2016 02:25 PM
Man, what you can do with a K-3 joelovotti Pentax K-3 3 08-20-2014 07:09 PM
What are your most used lens and what do you use them for? What lens do you have that pearsaab Pentax K-5 44 06-04-2012 09:23 AM
All times are GMT -7. The time now is 02:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
