Finally received my K-1, slightly used, from the Fred Miranda forum.
Here are some initial thoughts.
It is a lot smaller than I thought it would be. I also have the Nikon D810, and the size comparison is hard to see in pictures, you really have to hold both to appreciate it. The K-1 is very similar in size to the K-3.
The build quality, to expected, is superb. But I wouldn't say it is better than the D810. I wouldn't hesitate to shoot in harsh conditions with either of them (with the proper lens of course).
The shutter button does have a mushy feeling...but I set up the camera for back button autofocus, so I don't care
I may be in the minority, but I like the knob on top. I like being able to twist the knob to change the ISO as opposed to hold a button and twist a dial simultaneously.
Also, I may be in the minority for this too, but I like the top LCD display the size it is...sure it is smaller, but it has all the parameters i need on it.
The files it generates are great. Definitely as good as the D810.
I wish I still had the 35 f1.8G and 85 f1.8G nikkors so I could take a comparison shot between the FA 31 and 77mm limiteds. But needless to say, the limiteds are MUCH more svelte. The in-lens motors really take up a bunch of space (neither of these Nikkors have VR, so it is the AF-S motor that makes the lenses a lot more chunky than their Pentax counterparts). These lenses look so sexy on the K-1
I also wish I still had the Samyang 135mm f2.0 to compare to the K135 f2.5, but the Samyang is MUCH bigger. The K-1 was built to have the K135 f2.5 mounted to it
I don't know if it is placebo, or what, but it seems like the green button (stop down) metering is a lot more accurate with the K-1 than with older models.
Side note: if you like the 77mm focal length on APS-C cameras, you owe it to yourself to get a fast 135mm (f2.8 or faster). If you don't mind the size, the Samyang is superb. But it is big. The Pentax 135mm (K135 f2.5 or F/FA 135 f2.8) are fine too, just not quite as sharp or as well corrected, but MUCH more compact. But to me 135mm are special on full frame cameras. The OEMs have neglected this focal length for too long. End rant.
I love the K-1 rear screen. I really missed that feature on the D810...it opens the door to a lot more creative perspectives. Sure you can hold your D810 an inch off the ground and *guess* that you are getting a good shot. All the guess work is eliminated with the tilting rear lcd
One hold over on the K-1 from older Pentax models that really annoys me though is how when you zoom in for precise manual focus, it zooms out when you half press the shutter
Gosh how I hate that
If someone knows some way to defeat that, I am all ears
The K-1's autofocus does hunt more in lower light than the D810. Of course that is also a function of the lens used, and I was using a 77mm for my initial tests. I would love to see how the K-1 + 70-200mm combo handles low light.
Also, I cannot wait for a 24mm (or wider) prime! (Ricoh, if you are listening, I don't need a f1.4, a f2.8 will be fine
) That plus the 31 + 77 combo would be an awesome travel package! Oh well, i have the DFA 15-30mm to hold me over until that one arrives.
Soooo...this is is just initial test. I have not yet played with pixel shift. But overall, this is definitely the camera that Pentaxians deserve. We all know the strengths and weaknesses of Pentax system as a whole. But I think Ricoh has hit a homerun with this camera. A few more primes and we will have a truly great system as a whole.
