06-23-2016, 07:23 AM   #1
Wireless Triggers
So I've done a bit of searching and can't seem to find the right answer, but I am hoping to find some wireless triggers. I just got a K-1 after selling all my Canon gear. I had a K200D about 6 years ago and loved it. Could never get the 7D to make pictures as well as it did(Probably that CCD in the K200D).
For the Canon I used Yongnuo 603 Wireless flash triggers to activate the shutter. I see that the K-1 has IR sensors in front and back, but I am sometimes out of direct line of sight of the camera and the RF-603's were awesome for triggering the shutter exactly when I needed.
Since Yongnuo doesn't make a Pentax version, what do I need to buy to get a working set with the Pentax? I sold off the triggers thinking I would need a new set, but it seems that maybe they would have worked with a new cable, but I can't seem to find that answer.
06-23-2016, 07:50 AM   #2
Yes, your Canon RF-603s would have worked. Sounds like you are speaking of just using them as shutter triggers and not flash triggers. The Nikon version of the RF-603s are a little better for Pentax with flash, because they wake from sleep for Pentax, vs the Canon ones do not. As far as the cable goes, it is just a standard audio cable on both ends, 3.5mm? I don't think the Nikon version comes with that cable. If you think you might use them for flash in the future, the newer RF-605s have an LCD screen on them, but are about $10 more and are a little bigger.
06-23-2016, 08:40 AM   #3
QuoteOriginally posted by jake14mw Quote
I do occasionally use them for their intended purpose. So you would recommend the Nikon version?
These?
https://www.amazon.com/YONGNUO-Wireless-Trigger-Shutter-RF605N/dp/B00OLOIJG8...ywords=RF+605N
And the headphone jack is the typical 2.5mm headphone jack correct? So this cable would probably work?
https://www.amazon.com/Steren-feet-2-5mm-Male-Stereo/dp/B00291F4RM/ref=sr_1_...2.5mm+to+2.5mm
06-23-2016, 10:24 AM   #4
I've used the Vello Shutterboss for light-paintings on K20 & K3 without any failures, haven't tried on K1 yet but imagine will work. Worked well past 30ft through stone walls.
Also use the Yongnuo 560 for flash trigger & Nikon version does wake from sleep mode.
If you were happy with the Yongnuo, I'd stick with them, you'll get the dual purpose.
06-23-2016, 10:55 AM   #5
The Flashes, Lighting and Studio sub-forum on PF is worth exploring for Pentax flash related topics. A wealth of info and expertise ...
Also: the Cactus v6 radio trigger is something you should check out if you prefer manual flash.
answer, canon, dslr, full frame, full-frame, jjc, k-1, k1, k200d, pentax, pentax k-1, shutter, triggers, yongnuo
K-30 wireless flash triggers krishna203 Flashes, Lighting, and Studio 3 11-24-2015 06:31 PM
K-S2 problems with wireless flash triggers Mikebaum Troubleshooting and Beginner Help 8 11-05-2015 09:55 AM
Wireless Triggers for the Q DaveInPA Pentax Q 11 01-04-2015 02:02 PM
Wireless triggers! treebeard Flashes, Lighting, and Studio 9 11-09-2013 08:46 AM
Ebay Wireless triggers Gaelen Pentax Camera and Field Accessories 11 10-11-2007 07:33 AM
All times are GMT -7. The time now is 10:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
