Show Printable Version 3135 Likes Search this Thread
02-02-2017, 12:29 AM - 6 Likes   #271
noelpolar's Avatar
QuoteOriginally posted by ranchy Quote
Wow.. how did you go so close with a CV20...
Nice macro shot!
Just one of those things..... last year about the same time I got a similar shot with the DA10-17. I saw this one whilst working in the yard, I went and got the K-1, tripod and a 40" reflector ... set it all up and moved closer and closer to about MFD, had to squeeze the tripod legs together to get close enough... bent the round reflector in a big U and lit him up etc.... first with the white side...then with the silver.... didn't seem to bother him. He took off some time later.
Off course, if you went out to get the shot it would never happen!
Last years
by Noel Leahy, on Flickr
02-02-2017, 01:50 PM - 5 Likes   #272
Newhaven Harbour, Edinburgh
K1, 15-30, ISO 800, f9.0, 1/4s, 24mm
---------- Post added 02-02-17 at 01:51 PM ----------
Newhaven Harbour Edinburgh
Pentax K1 & 15-30
30mm, f9.0, ISO 100, 0.6s
02-02-2017, 02:52 PM - 5 Likes   #273
Miguel's Avatar
Ice Spikes
Last month we had a longer than usual freeze that created some neat structures.
These are ice spikes on a twig.
K-1, Voigtlander SL 125mm, f 13 @ 1s, ISO 100
M
02-03-2017, 07:58 PM - 1 Like   #274
cdd29's Avatar
Williams covered bridge
The Williams Covered Bridge is located just outside of the small village of Williams Indiana, along Indiana state road 450. It crosses the east fork of the White River, just downstream from the Williams Dam, which used to be a electric power generating station.
The bridge is a Howe Truss design and was built in 1884 by Joseph ‘J.J.’ Daniels. Its two spans cover a total length of 373 feet (114 m), with a deck width of 14.7 feet (4.5 m) and a vertical clearance above deck of 19.2 feet (5.9 m).
PENTAX K-1  Photo
02-03-2017, 11:10 PM   #275
QuoteOriginally posted by noelpolar Quote
20/3,5 Voigtlander.... up real close for this one....
Voigtlander 20/3.5
Excellent photo. Beautiful wings, nature's engineering is a marvel.
02-04-2017, 07:58 AM - 1 Like   #276
A couple with the DFA 24-70.
Paoli Square
Barn at Sunrise
02-06-2017, 06:47 AM - 5 Likes   #277
Before Dawn Patoka Lake.
Sunrise Patoka Lake.
02-06-2017, 01:55 PM - 12 Likes   #278
Aperture....
Inside a Kodak Retinette 1B
Pentax K-1
smc PENTAX-D FA MACRO 100mm F2.8 WR
ƒ/2.8 100.0 mm 30s Iso 400
02-06-2017, 05:56 PM   #279
Great image!
02-06-2017, 06:28 PM   #280
QuoteOriginally posted by ZeGaby Quote
Aperture....
Pentax K-1
Wow nice!
02-06-2017, 06:39 PM   #281
mee
Nice images, Matt! I especially like #1 with the blue of Venus belt rising up from that rock notch.
I'm just starting to play with PS -- did my first test shots from a local peak recently.
At first, I was amazed at the overall sharpness -- much sharper than a normal shot. Then I was horrified to see various checkerboard and zipper-edge artifacts where distant cars, not-so-distant foreground veg moved, and perhaps the camera shifted the tiniest amount. But finally I realized it's only visible at pixelpeeper resolutions and that the artifacts will disappear like a dither or halftone at a modest dpi.
SOOC K-1, SIgma 12-24 EX DG @12mm, 1/350, f/11, ISO 280:
center crop from above image:
There is quite a bit of detail in the crop considering you're using an ultraultrawide lens. And I appreciate you offering up an example SooC as it is much easier to get a feel for the lens and camera vs the lipstick and eyelinered photoshops.
02-07-2017, 03:12 AM   #282
Wow nice!
Thanks !
02-07-2017, 06:32 AM - 4 Likes   #283
Patoka Lake (DFA 15-30 with pixel shift)
Full size on Flickr is pretty impressive...
02-07-2017, 10:44 AM   #284
photoptimist's Avatar
QuoteOriginally posted by mee Quote
Thanks!
I've really enjoyed the Sigma 12-24 DG even if it is physically large and optically slow. It's been great for low-distortion UWA landscape and architecture applications on the K-5 and now feels insanely wide on the K-1. It's sharp enough wide-open for astrophotography (f/4.5 & ISO 3200 does a nice job for meteors). And it's very sharp at 12mm & f/8 or f/9.5 although less sharp in the corners at 24mm.
As for SooC, that's my preferred workflow at the moment -- I'd rather be outside with my camera than inside with my computer.
02-07-2017, 01:29 PM   #285
QuoteOriginally posted by carolina_sky Quote
A ten stop will almost always result in a >30s exposure meaning you can't use pixel shift with it. And if not, it would almost certainly affect the sharpness, it's an extra piece of glass/resin in the way. My Lee 10 stop certainly affects picture sharpness to some degree. More expensive ones like the Singh-Ray mor-slo might affect the sharpness less.
Dang, it doesn't work with the bulb timer. That's lame.
control, dcu, distagon, dslr, flickr, full frame, full-frame, image, images, k-1, k-1 ii, k1, movement, night, pentax, pentax k-1, pixel, pixel-shift, pixels, ps, road, sec, secs, shot, thread
Pixel Shifted Snoqualie Falls using 24-70mm Pentax AwesomeIan Pentax K-1 & K-1 II 20 07-01-2016 09:32 AM
How to display pixel shift images. TroutHunterJohn Pentax K-3 & K-3 II 8 11-10-2015 07:58 AM
Sensor shifted composite shot of 40MP resolution MichalW Pentax DSLR Discussion 23 01-17-2015 03:44 AM
Shifted from Canon to Pentax ruwanal62 Welcomes and Introductions 5 03-15-2014 11:06 AM
Image count on K200D has shifted to a high number Stratario Pentax DSLR Discussion 6 06-29-2008 05:52 PM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
