I Know every one seems to have totally dismissed this from day one
However working thru it step by step i think it could be useable, but it will take bit of heavy lift in post production
this is just work in progress ( the big lesson is turn of the shake reduction .....i will say it again turn of the shake reduction)
as you can see in this clip i didn't switch off SR,and it sort makes camera shake even worse ...and when you try and use a stabilizer on it in post ....it messes that up as well
it's handheld on a 28mm, its sort of got a 16mm thing going on colour wise..... but that just me ...i was just sort pushing everything around to see what you could do
i,m going carry one playing with the video aspect of the camera and see if there are any preferred settings/work flows i can share
