07-05-2016, 09:42 PM   #1
K-1 Bricked in LV
Has anybody else had their K-1 lock up going into Live View, never to return? I was testing my new replacement copy of the Rokinon 14mm f/2.8, pressed LV to grab 16X focus, and the screen went dark. Turning off the camera did nothing, with the screen very dim like a TV with no signal and the top screen staying on. Removing and reinstalling the OEM battery with full charge got me back to the normal screen after a double mirror flap, but no AF (on AF lenses), shutter or LV. (Switching to LV completes the cycle.) Reinstalling FW 1.10 and changing to another full OEM battery had no effect.
This failure brings me to 60% on bodies, pretty shabby. Fortunately this happened a day before travel to Kauai, so I can fall back on the (warranty-repaired) K-3 II with no UWA.
07-05-2016, 09:53 PM   #2
QuoteOriginally posted by saxt001 Quote
Was everything OK after you switched back to LV?
07-05-2016, 09:56 PM   #3
No, Adam, it goes to square 0. The LV screen goes dark, the top LCD stays lit, and it won't power off. Funny business.
07-05-2016, 09:58 PM   #4
jatrax's Avatar
Have you tried a different lens to eliminate that?
07-05-2016, 10:03 PM   #5
Yes, tried the FA77 and DA* 60-250. I can switch crop, ISO& aperture settings but neither shutter nor AF are happening.
FWIW the Rok 14mm works fine on the K-3 II and is not decentered like the used copy I bought from and returned to B&H.
07-06-2016, 01:38 AM   #6
Tas
I have had issues with LV on the K-1 and it's hard to describe but it appears to be an issue with the mirror, though mine never got as bad as you describe.
When it happens to me I see what looks like a black bracket and I can see through some sections of the bracket to the view through the lens. The first time it occurred to me was in low light so it looked like the screen was on but there was no image.
I could get the camera back to normal by pressing LV again though when I do this there are times where there is an audible difference in the mirror actuation. The issue is most prevalent when I go to use LV whilst in mirror lock up. The odd mirror noise occurs other times when not using LV and mirror lock up so my issue might be completely different.
If you have the camera still turn it on and press LV, if the blacked out LV screen appears take the lens off and see if the mirror is still down. This is what happened in one instance for me (and I need to check this again the next time it happens).
I still need to send my camera back for a check up however as it still works correctly 98% of the time I've put that off for now. When I do I will provide an update on the forum and ask that you do the same if you have any updates.
So far this is the only Pentax DSLR out of four that I've had issues with so whilst this is a pain in the bum I think it's just my turn for the Monday camera.
Tas
07-06-2016, 06:22 AM   #7
WPRESTO's Avatar
The K1 seems to have a larger number of annoying glitches and/or more problems with QC than other Pentax bodies introduced over the past decade. Very disappointing and and discouraging considering the long delay we awaited the camera's release. Were they trying to detect and correct a myriad of other similar problems? Will all of these issues be resolved with updated firmware? Who knows? (only the phantom Ricoh technicians)
07-06-2016, 06:47 AM   #8
QuoteOriginally posted by Tas Quote
Tas
Agreed, I'm feeling the pain of the 1st generation camera. The mirror is up when the LV and camera are frozen. It went back to normal and then quickly got hung up again with a press of LV when I checked this morning. Back in the box she goes.
07-06-2016, 08:48 AM - 1 Like   #9
You have experienced a juvenile failure; you have a defective camera. Return under warranty.
07-06-2016, 10:48 AM   #10
QuoteOriginally posted by HoustonBob Quote
Forgone before initial post. I'm interested in this failure mode among our compatriots.
07-22-2016, 06:42 PM   #11
Update: 7 business day turnaround from Precision for "flex circuit and CPU repair." Nothing major, just a bad CPU.��
07-22-2016, 07:49 PM   #12
jpzk's Avatar
At least they could find the problem.
Nothing major? circuit and CPU repair seems like a big deal to me !
Did you already get your K-1 back ?
07-22-2016, 08:11 PM   #13
I wonder how/what/if there was something specific about the Rokinon 14mm's mount connection that triggered that. Flex circuits and CPU's normally don't die unless there is some electrical disturbance.
07-22-2016, 08:21 PM   #14
I wonder how/what/if there was something specific about the Rokinon 14mm's mount connection that triggered that...
I would be very surprised since the normal connection through all of the Rokinon's active mount contacts is to complete the circuit to the body...fully passive. In the case of fault, the lens maximum aperture and aperture range is simply misread.
07-22-2016, 09:59 PM   #15
Overnight shipping got it right back to me, no issues with the quiver of lenses. I think the switch to LV with the Rokinon just happened to be the vibrating straw that broke the camel's back. I'm just glad it happened before and not during vacation.
battery, dslr, full frame, full-frame, k-1, k1, lv, oem, pentax k-1, screen
K-1, LV in low light jcdoss Pentax K-1 2 06-20-2016 06:49 AM
K-3II-normal to hear movement withing the camera in LV mode? blueox4 Troubleshooting and Beginner Help 2 10-31-2015 01:21 PM
FIXED: K-3 bricked after firmware update attempt maxxxx Pentax DSLR Discussion 31 06-08-2015 01:48 PM
Pentax K-01 Bricked? mtmgiants Troubleshooting and Beginner Help 11 12-10-2014 10:30 AM
K-x bricked after 1.01 update raver1414 Pentax DSLR Discussion 23 12-09-2009 11:37 AM
All times are GMT -7. The time now is 09:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
