07-09-2016, 09:45 PM   #1
eaglem's Avatar
Any ideas?
I thought I'd try my Metz 58 AF-2 on the K-1 to see if it works okay but was surprised to find the metal mounting plate is too wide to fit on the K-1. Have they made the flash mount smaller on the K-1 or has something else happened. Or can the flash mount be altered to fit the K-1? Any help would be appreciated.
Found with a bit of jiggling the Metz went on because it is a very tight fit which I suppose it needs to be.
07-09-2016, 10:17 PM   #2
jatrax's Avatar
The flash mount has not changed. Both my Nikon SB-26 and my Metz 48 work fine. Are you sure it will not fit?
07-09-2016, 10:34 PM   #3
eaglem's Avatar
Yes I corrected my post when I found with a bit of jiggling the Metz went on but it was a tight fit which I suppose is good. It works well in PTTL mode so that's a bonus. I rarely use a Flash but it's good to know it will work when and if I need it. Thanks for your reply.
07-10-2016, 04:34 AM   #4
WPRESTO's Avatar
Make sure the locking pin is fully retracted. I've struggled mounting a flash and then embarrassingly discovered the locking wheel wasn't quite fully turned to the release position leaving a tiny bit of the pin protruding.
07-10-2016, 04:36 AM   #5
eaglem's Avatar
QuoteOriginally posted by WPRESTO Quote
Yes I checked that when I thought it wasn't fitting but that was okay, was just a very tight fit.
07-10-2016, 05:50 AM   #6
Paul the Sunman's Avatar
No problems with the 52 AF-1.
dslr, flash, full frame, full-frame, k-1, k1, pentax k-1
Any ideas for fireworks photos with a K-1 SteveD Pentax K-1 10 07-11-2016 06:28 PM
Silent focusing, any ideas? rrstuff Pentax SLR Lens Discussion 25 06-19-2015 03:46 PM
Any resource ideas please? adwb Photographic Technique 2 09-11-2014 11:08 AM
MZ-M problems, any ideas? pero Pentax Film SLR Discussion 4 05-31-2011 03:26 PM
Does anyone have any ideas? Jimfear Pentax SLR Lens Discussion 12 07-17-2007 02:37 AM
All times are GMT -7. The time now is 09:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
