Originally posted by todd got to see the load of crud stuck on my sensor
Originally posted by todd Tried using swabs today and under the loupe it just looks like I am smearing stuff around...
Hi
I keep preaching here to remove crap from the sensor as soon as you discover it.
I read all the time, when the blower can't remove it (which in itself is bad advice - let the hate mail begin) just let it be and remove it from the picture in post. I am afraid, not the brightest idea.
Why is the blower not the best idea ? Well, you may just quickly and very temporarily shift the offending matter only to come back at a later stage. Pointing the lens mount to the floor at first thought seems to be logical (and it is when changing glass as dirt is less likely to fly up into the mirror box) but there is no guaranty the fluff you just blown off the sensor (if it even comes off) will obediently sail down through the lens mount and hit the floor. Don't forget, the very low weight of whatever lands on the sensor is the reason it floated through the ambient air, so why should it fly out again particularly when you keep puffing air. It is not suddenly heavier then what it was before. I read all the time, the blower did the trick, sure, but only for the time being. When I find stuff on my sensor it is removed, not just dislodged ! This way it can never make another appearance.
To cover all objections to the contrary which will be posted now, I concede there is a likelihood the stuff which just got blown off the sensor may actually not return because it got stuck on some surface inside the mirror chamber, but it is equally or even more likely it will find itself back on the sensor sooner or later.
Now, why should you remove dirt from the sensor as soon as you possibly can ? As stated in my previous posts most stuff which lands on the sensor will be of organic matter. What does organic matter do when humidity builds up in the mirror chamber ? It "blooms". This can be observed when the dirt spot develops a halo. I bet you have seen this before. Give it enough time it will literally "weld" itself to the sensor surface. It will stick like - you know what !
When you are stiff with fear of damaging the sensor removing a simple piece of crap in time, you will be paralysed from the waist up when you face a cleaning job of massive proportions. You neglected to take the s***t off immediately when it was still just one or two fresh little pieces and now you pay the price. With every day the crap remains on the sensor the harder it becomes to remove it and over time you collect more and more. Trust me, I know !
Originally posted by todd Also going to contact my local camera tech tomorrow (whom I trust since he's repaired my gear many times) to see what he charges to clean sensors..
Yeah, right! There are some good operators no doubt, but most of the time they are not any better then you are and they employ the same cleaning method as you do. You just have to overcome your fear, that is the main thing. And as stated before sensors are more robust then you think. Manufacturers know it is a user serviceable part so it has to be cleanable. I know of a few cases where the cam came back in a worst state then when it was before, even with damage. Yeah, but then I hear you say it is their responsibility to make good. Fat chance, just read carefully the fine print on the repair agreement form. Particularly the part titled "Disclaimer".
Just overcome your fear, get a bit of practice and do it yourself. (Practice on a new CD because it scratches infinitely more easily then any sensor will so you know how hard you can go at it). Unless you have a bad shake or tremor, nobody will be better then you are, because you care more.
Cheers
