Originally posted by Dan Rentea The image below is not sharp when you zoom in, at least the lady is not sharp. It could be back focus, or camera movement.
Thanks for your reply.
Yes, it is the Tracey Curtis-Taylor photos that I am puzzled about.
The engine doesn't show much sign of camera movement. (These were 1/200 second with SR
on).
Originally posted by Dan Rentea See also the image below. Your settings were 150 mm, 1/2000 sec, f/5.6, ISO 200, yet you lose all the details from the plane when you zoom in. It looks like it was taken at ISO 12800.
I was panning
with the plane moving from left to right. So I was panning
against the plane moving from right to left. My experience is that this makes a massive difference.
Consider the left-to-right plane in the first of the cross-photos. It was about 654 x 351 pixels on the sensor, about 0.2 megapixels. I don't have high expectations of fine detail in an image from such a small part of the sensor in these circumstances.
Also, I've checked in Lightroom where the center of the sensor was. (I was using center-spot focusing). Mostly the center was sky in those photos, so the camera wasn't actually focusing on the planes! (Bad panning on my part. My left arm injury is really causing panning problems).
I think they were doomed not be of competitions quality! I posted them to illustrate that even with the relatively low burst rate of the K-1, it is possible to get several frames with both planes in. (Somewhat to my surprise). Now I've got to get the details right!
Originally posted by Dan Rentea And take a look also at this image below. Again, there are no details when you zoom in, despite you used a low ISO (ISO 320).
I think there is more detail just behind the propeller. And the further struts don't appear to be sharper than the nearer struts. So I don't think there a back-focus problem. (I couldn't find
any sharp grass).
I suspect 2 problems: I was hand-holding with an injured left-arm at 450mm
with maximum aperture. And it was taken at 14:30, which was probably about the hottest part of the day.
But I agree it should have been sharper.
Originally posted by Dan Rentea That is why I asked you if you had any problems with your camera or lenses. I know that weather conditions (heat generated from the ground in a hot day) can influence the image quality, but here it looks like something went wrong...
The ones I'm concerned with are the Tracey Curtis-Taylor photos. I can't think of a good reason for those problems. She was only moving significantly in the photo where she is side-on.
