07-19-2016, 09:46 AM   #1
K1 and Tamron SP 90mm f2.8 macro lens
Have any K1 users tried this lens and if so what sort of results did you get.
I am at present an APS-C shooter - K5, K5iis and KS2. I have several cropped lenses including 16-50 and 50-135. My FF lenses consist of SMC A lenses - f1.4 50mm, f2.8 28mm and 135mm. The Tamron is the only digital age auto focus FF I own.
As the Tamron is full frame stepping up to the K1 if and when the price drops it would be my only FF auto focus until the piggy bank was full again. My main style is street work and portrait so I am not looking to use the Tamron for macro. I agree with all the revues about the sharpness of this lens and I am curious if it as good on the K1 and also if there are any issues with this lens being fully compatible with the K1.
07-19-2016, 04:09 PM   #2
Paul the Sunman's Avatar
Brilliant. Nothing more to say.
K1 + Tamron 90mm SP Di Macro @ f/8:
07-19-2016, 04:48 PM - 2 Likes   #3
My version of Tamron SP 90 (non-di 072E model) is great on the K-1. Meters in all modes, sharp, pleasing bokeh and fast auto focus for the screw drive. The focus limiter works great too. Don't shoot much portrait but thing this lens should do you well.
This and the others lenses you mentioned should give you great coverage and IQ already. Don't forget to try your crop lenses also. Been very pleased with some of the results from mine. (DA70 is as fast and sharp on K-1 as with K3 with no vingetting or loss in the corners.)
Not a true macro but gives an idea of sharpness & performance, center crop shot with limiter & auto focus, f11, 1/200 & flash, hand held from about 18 inches away after dusk.
07-19-2016, 06:40 PM   #4
hcc
hcc's Avatar
QuoteOriginally posted by pcrichmond Quote
WHOAA! Superb. Well done and thank you for sharing.
07-20-2016, 01:46 AM   #5
QuoteOriginally posted by Paul the Sunman Quote
Superb, thanks for your reply.
07-20-2016, 01:49 AM   #6
Thanks also for your reply, just the information I was looking for. The cropped lenses are definite keepers, even if only used in the crop mode it should be the same as using K5 but with K1 advantages.
07-20-2016, 07:03 AM   #7
I can see by Paul the Sunman's post (as others I've seen here of PF) most of us find the K-1 & Tammy 90 an enjoyable combination.
Hope you do too when you get the K-1.
07-22-2016, 02:36 AM   #8
MikePlunkett's Avatar
I've had a Tamron SP 90mm for a while and yesterday I put it on my K-1 and gave it a go. Some of the results are here. All in all I absolutely love this lens on my K-1 - with the exception of the ladybird chrysalis all those shots were taken handheld and required only small amounts of processing in Lightroom to get to a presentable standard.
07-22-2016, 02:42 AM   #9
Marketplace Reseller
vjacesslav's Avatar
Astonishing, I like that picture with Red watering....
07-22-2016, 08:12 AM   #10
QuoteOriginally posted by MikePlunkett Quote
Thanks Mike, great result. The lens performs well on the K1, all I have to do now is take the plunge.
03-09-2017, 01:05 PM   #11
QuoteOriginally posted by philanker2012 Quote
I have this lens and it is the only lens that I've used on my K-3 that doesn't work at all on the K-1
03-09-2017, 02:12 PM   #12
QuoteOriginally posted by bpcarlson Quote
This lens works perfectly on the K-1.
03-09-2017, 02:15 PM   #13
I wonder what I'm doing wrong? I will try it again tonight when I get home and see what happens.
03-09-2017, 02:40 PM   #14
Does it click in place when you mount it?
When you say it doesn't work, what do you mean? No electronic contact? Auto aperture doesn't operate? The aperture lever was bent when I received mine (new!); I just straightened it by hand and all was well.
03-09-2017, 02:47 PM   #15
It works perfectly on my K-3. When I mount it on the K-1 and turn on the camera, the image is completely out of focus. There is no auto focus action happening either when i touch the shutter button. I tried changing the settings on the lens from manual to auto to see if that would make and difference.
90mm, dslr, ff, focus, full frame, full-frame, k-1, k1, k1 and tamron, lens, lenses, pentax k-1, sp 90mm f2.8, tamron, tamron sp 90mm
Macro A few from the Tamron SP AF 90mm F2.8 Di Macro 7.62lew Post Your Photos! 2 06-17-2016 08:21 PM
For Sale - Sold: Tamron adaptall sp 90mm f2.5 ad2 52bb macro lens davidxgreen Sold Items 7 04-02-2016 05:49 AM
For Sale - Sold: Tamron SP 90mm f2.8 (non Di) AF macro lens (172E) (Worldwide) EricR Sold Items 2 04-09-2011 09:56 AM
All times are GMT -7. The time now is 01:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
