08-26-2016, 02:14 AM   #16
Banned
There must be some problem with the SD card slot.
There must be some problem with the card slot. Try blowing air out or cleaning with some folded paper. Often SD card slot gets jammed or blocked by dirt or dust inside.
08-26-2016, 10:59 PM   #17
What kind of cloth would you suggest. I suspect your suggestion - renault- is the most likely, there is some dust or dirt in the slot. Blowing out with a rocket blower has not worked.
08-27-2016, 03:30 PM   #18
eaglem's Avatar
It also pays to clean the contacts on your SD Card with a soft Pencil Eraser at frequent intervals which will help greatly. Carry an Eraser in your Camera bag incase of emergencies.
blower, breath, card, cards, dslr, error, full frame, full-frame, k-1, k-1 memory card, k1, memory, moisture, pentax k-1, sensor, slot, time
K-3 II Memory Card Error K David Pentax K-3 6 10-22-2015 06:19 PM
memory card error Willaom Poh Visitors' Center 9 10-20-2015 05:20 PM
Memory Card Error Doggai Troubleshooting and Beginner Help 3 08-14-2014 04:34 PM
Memory Card Error On K-5 zeda3000 Pentax K-5 16 06-01-2014 04:51 AM
K-m memory card error wgl58 Troubleshooting and Beginner Help 2 01-18-2011 12:22 PM
All times are GMT -7. The time now is 10:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
