08-01-2016, 09:59 PM   #16
thanks Ken
the colors seem deeper , more vivid on the K- 1
maybe DR gives that impression.
08-01-2016, 10:27 PM   #17
Class A's Avatar
QuoteOriginally posted by christiandre Quote
first impression : the colors seem deeper , more vivid on the K- 1
The white balance is definitely warmer.
Noise seems slightly better controlled on the K-1.
@Ken Pimontel
How did you develop the images?
Seems like you used ACR.
Given that Adobe applies different processing depending on the camera brand/model, I'd say it would be more reliable to use dcraw or perhaps RAW Therapee for noise comparisons.
08-02-2016, 01:56 AM   #18
kh1234567890's Avatar
Why do you get more purple fringing with the K-1 ?
08-02-2016, 07:41 AM - 1 Like   #19
AggieDad's Avatar
QuoteOriginally posted by Rupert Quote
Glad to help. It only fell about 4 feet...onto carpet...but, it had the Bigma 50-500 mounted and pulled the lens mount out of the camera, I had a heck of a time getting the lens mount off the Bigma, it was stuck. Fortunately the Bigma didn't get any damage at all, just the K5IIs.
I suggest a concrete drive, and faking a heart attack....cheap lens mounted...that way you can get some sympathy which may help get you the K1. Personally, I cried like a little baby for 30 minutes and that's when Mrs Rupert handed me her credit card for the K1. Of course, I am a pro at this after 50 years with Mrs Rupert.
She blamed the accident on my being old and with "infirm mind". She might be right...I forgot to tell her the Bigma was not damaged and so she let me get a new Tamron 70-200 2.8 too! Gotta do some of that Big Brain Thinking, you know!
Regards!
Okay. I think this might be doable. Let me just run through it:
  • Concrete drive: CHECK
  • Faking heart attack: not needed - already very old & clumsy - so: CHECK
  • Cheap lens: CHECK
  • Cry like a baby (I'm good at this): CHECK
  • Sympathy from AggieMom: UH-OH... this could be difficult
Well, I'll carefully put together a plan and work on the correct timing for an event. Who knows? It might all come together.
Thanks for the tips.
Don
08-02-2016, 08:52 AM   #20
Rupert's Avatar
QuoteOriginally posted by AggieDad Quote
I do what I can! Good Luck!
08-02-2016, 09:17 AM   #21
Ken Pimontel's Avatar
@Ken Pimontel
Developed in Lightroom, Color checker profile for each, same white balance, no ambient light.
08-02-2016, 12:05 PM   #22
  • Cheap lens: CHECK
Don
Face it Don you are old and forgetful. Just say you misplaced the K-5II and need a new camera.
08-02-2016, 09:37 PM   #23
Class A's Avatar
QuoteOriginally posted by Ken Pimontel Quote
Thanks.
The fact that you used a color checker profile for each helps quite a bit, but LR (which has ACR under the hood) could still apply different levels of baseline noise reduction. A "0" in an LR setting means nothing; it pretty much never means "neutral".
08-02-2016, 10:41 PM - 1 Like   #24
K5IIs vs K1 vs K5 - Embedded profiles
I redid the test this morning.
All studioflash, no ambient, no SR, FA77 at f8
Development in Lightroom.
08-02-2016, 10:46 PM - 1 Like   #25
K5 vs K5IIs vs K1 - DNG Profile Editor profiles
Here with profiles made in Adobes DNG Profile Editor.
FYI, the K1 sensor seems bluer and greener. Needs +50K and -4 magenta in stead of K5 -6 magenta
---------- Post added 08-02-16 at 10:47 PM ----------
Thanks.
FWIW, I use LR 5.7.1 I do not believe it knows the K1.
The order of the images is K-5IIs, K-1 and K-5.
08-02-2016, 10:49 PM - 1 Like   #26
K5 vs K5IIs vs K1 - crops
And the crops pushed 3 stops.
What are your thoughts on the fringing on the K1?
Thx for all the input guys!
08-02-2016, 11:21 PM   #27
I cannot see any fringing.
08-03-2016, 01:39 AM   #28
QuoteOriginally posted by jbinpg Quote
I can, round the ColorChecker box details.
Presumably the order of the cropped shots is K-5iis, K-1 and K-5 ? In that case it is the K-5 AA filter doing what an AA filter is meant to do ...
08-03-2016, 02:43 AM   #29
QuoteOriginally posted by kh1234567890 Quote
Correct: the order is K-5IIs, K1 and K-5
08-05-2016, 04:23 PM   #30
AggieDad's Avatar
QuoteOriginally posted by Rico Quote
Boy, that is the truth! But I think she put one of those electronic finder thingies in my camera bag. She already put them on my keys and my Nook.
dslr, full frame, full-frame, iso, k-1, k1, k5iis vs k-1, lr, pentax k-1, post, profile, profiles, test, vs, vs k-1 crop
Has anyone tried the Sigma Art 30 1.4 on Pentax K-1? Belnan Pentax K-1 18 08-30-2019 01:20 PM
Anyone tried LR plugin with K-5ii? gsrokmix Pentax K-5 7 07-08-2016 12:37 PM
Comparison Request: K-1 in crop mode vs. K-5 IIs geomez Pentax DSLR Discussion 9 05-07-2016 08:45 PM
Anyone tried the Wollensak 6.5mm f/1.8? murrelet Pentax Q 4 01-30-2015 04:46 PM
Anyone tried the WG-1 yet? CaymanImaging Pentax Compact Cameras 20 04-16-2012 11:30 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
