09-05-2016, 11:28 AM   #166
QuoteOriginally posted by awscreo Quote
Basically just a cap on test - 80s at 3200 iso, exposure boosted to +1 in lightroom (at base exposure it was too dark, my mistake for not running it longer), with and without NR, color noise reduction at 0.
There is no correct exposure for a cap-on test. Anything in the capture is noise and adjusting the noise in PP is just modified noise. If there was little to see at ISO 3200 and 80s that is a good thing.
09-05-2016, 01:32 PM   #167
I included a link to raw files, you can download them and have a look. They looked very clean to me. So glad my unit seems to be just perfect, no mirror lock-ups reported on the forum, no excessive noise. I was worried after I read all this stuff on the forum.
09-05-2016, 02:19 PM   #168
That is very cool and I am pleased for you and hope that your experience continues to be troublefree. Forum posts are sort of a strange thing. Sometimes a problem report is traceable to user error and sometimes to false expectations, but usually the problem is real. Whether a reported problem is random failure, the result of a design deficiency, and/or is a pervasive fault is more difficult to gauge. Forum membership, after all, is not a random sampling of camera buyers and oftentimes our users purchase with specific uses in mind. I have often thought that if there is a potential problem with any Pentax camera, the members of this forum will find it!
09-05-2016, 02:25 PM   #169
Yes, it's probably not only a pentaxforum issue, it's the internet, and the fact that people with issues will always be a lot more outspoken than those that are just enjoying the product they purchased. In any rate, I hope those with issues will get them resolved, because this is truly a spectacular camera, and it deserves the praise most of people giving it
09-06-2016, 08:24 AM   #170
MJKoski's Avatar
More info on this matter. Fellow finnish K-1 owner asked Focus Nordic (Pentax service in Sweden) about that black band on top of the image. Answer was kind of shocking - They are aware of it and the cause is sensor calibration which has NOT been completed in factory! The service points are currently being delivered the tools required to perform the needed operation.
This is related to small batch of K-1 bodies, not all of them. It should also explain why some unlucky ones have these noise problems.
This is not funny at all.
09-06-2016, 08:28 AM   #171
QuoteOriginally posted by MJKoski Quote
Your unit seems to be on a low end of quality control Hope they fix everything for you. I'd be very pissed off if I experienced those issues
09-06-2016, 08:34 AM - 1 Like   #172
MJKoski's Avatar
Yea, pissed is easy word for this. Especially when called a troll when participating in the discussion.
09-06-2016, 08:41 AM - 1 Like   #173
I don't quite understand the aggression towards someone that reports an issue personally. I saw some crazy holywars on dpreview forums, because of so many members of different systems are participating in discussions. Here however, it's a specialized pentax owner forum, and I though people would have more empathy towards one another since we're all in the same boat. Anyway, hope your issues are resolved quickly.
09-06-2016, 08:57 AM   #174
Tjompen1968's Avatar
Do you have a repair center in Finland or is it sent to Sweden?
I got an answer from the Swedish repair center today, after sending them some test shots with white noise, stating that the early cameras had not had their sensors properly adjusted. Not sure what it means but I guess I will send it in.
09-06-2016, 09:25 AM   #175
Then the question arises, how do you know if you should send it in?
If it's obvious it's obvious, but if it's quite ok? Could it perhaps be even better?
Do they have a date or serial number or something after which the cameras are supposed to be ok?
09-06-2016, 09:38 AM   #176
QuoteOriginally posted by Gimbal Quote
I have no idea. Maybe there is a press release in the making?
09-06-2016, 09:50 AM   #177
redpit's Avatar
That is bad news. I have a very early model and I have seen "bad signs" as those reported here. Now my camera is in service for fixing the stuck in manual mode problem. The service guy told me that the new spare part for the mode selector has different serial number, so this means they have redesigned it-fix it. When I mentioned the white dot issue he told me first thing first. Let's fix the selector and then you can check it... I have regretted it being an early adopter, that's for sure :-(
09-06-2016, 10:29 AM   #178
Hi,
Just did a very unscientistic (jk) test of my own sample.
Stuffed the camera in a closet, which was not completely light sealed. Hugged the camera with a coat to prevent light leak through viewfinder. Bulb mode f/32 (to minimize lightleaks from lenscap) 103" exposure at ISO 1600. High-ISO and long exposure NR OFF. Pushed +5 stops and am seeing mostly uniform, colored noise. Not the dreaded white spots. Camera temp according to EXIF tool was 25C.
These are just my observations, your mileage may vary. Also these results may not apply to heavy exposure stacking and other specific use cases.
Camera info for those interested in tracking down batch variations:
Firmware version 1.00. Bought in Helsinki, Finland. Pre-ordered and was from the first batch of the shop I got it from (AFAIK).
Camera info from EXIF-tool.
Manufacture Date : 2016:03:04
Production Code : 2.2
Internal Serial Number : 2001498
Last edited by fromunderthebridge; 09-06-2016 at 10:29 AM. Reason: Removed accidental quote
09-06-2016, 10:31 AM   #179
QuoteOriginally posted by Tjompen1968 Quote
If that is true it is exactly the same story like Nikon D810. Servicing activity on D810 was only adjusting some sensor parameters.
09-06-2016, 10:31 AM   #180
It seems possible that this could be a unit specific issue. (wrt. my previous post)
astro, camera, data, dfs, dot, dslr, exif, exposure, exposures, ff, full frame, full-frame, heat, issue, k-1, k-1 white dot, k-5, k1, nikon, noise, pentax, pentax k-1, type, viewer
For Sale - Sold: White Pentax K-r + White Kit Lens + 2 Extra Batteries + 1 Extra Charger MightyMike Sold Items 2 04-14-2015 07:21 AM
Lost white dot bassek Pentax SLR Lens Discussion 15 09-06-2012 10:22 AM
White Dot on 50mm f1.4 Super-Tak roboticspro Troubleshooting and Beginner Help 6 04-07-2011 03:03 AM
white dot on live view screen Shingkyo Pentax K-r 7 03-14-2011 06:54 AM
old lenses- that little plastic white dot? dandaniel Pentax SLR Lens Discussion 6 02-25-2009 02:13 PM
All times are GMT -7. The time now is 11:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
