Originally posted by Medex OK. I follow discussion in this thread. And this is my comparison of 4 different Pentax K-1 camera. The picture is below. The base picture is Medex-25600-30s-??*C done 10 days ago and I dont know the exact ambient temperature. But today I shot 4 more pictures with lens cap on, f22, 30 seconds at ISO 25600 in the dark room with OVF closed by hand. Other 3 samples are according the name. All samples where imported to the Adobe LR, WB Temp was set to 6000K, Tint to 0, Sharpening is Off, Color Noise Reduction is Off. Then all pictures were opened in PS as layers and different layers were exposed on the base picture using layer masks. Then the file was saved as 16-bit TIFF to Adobe LR, and Exposure was set to +3 eV. Then TIFF was exported to JPG and opened in Windows Picture viewer. Picture below is a snap (using Snipping tool).
Any thoughts?
P.S. I'm not satisfied with high-ISO pictures in my camera do to white dots. Maybe I expect too much?
P.P.S. Manufacture date of the camera is 2016-04-18. Production code is 2.2. Internal serial number is 2009913
Hi,
I don't know for sure, but somehow I feel that we have gone too far - with these conclusions. Okey, I understand white dot noise issue. It's nasty for them whose K-1 sensor produces these white dots too much. Especially if you make a lot of long exposures. BUT these "unscientific" sensitivity level tests... I'm not sure how accurate these test even are, and how significant... C'mon: ISO 26500, 30sec and then push up +3 eV in PP...That's quite extreme, or what you think? What is meaning of these so-called differences in real life shootings? ...Now we just look at these ISO25600, 30sec+3eV noise level collages. And we wonder - we don't even know for sure what we are looking at.
Okey, in real life, if we're shooting the starry sky at ISO 25600, 30sec. Then we process RAW file in PP, and push up eV a bit...If a little bit more sensitive sensor has given a little bit more "brighter" image, then we don't have to raise eV so much - and that's it. Or what do you say, whether this make any sense?
However, as I wrote, the white dot noise is a different issue, isn't different issue ?
Ari
P.S. Another thought: we don't have any references to other cameras. We do not know how others cameras differ from K-1, at same exposure values - whether this is usual, maybe even a normal variation?
