10-14-2018, 11:11 PM   #511
Markovo's Avatar
QuoteOriginally posted by micromacro Quote
I usually don't shoot with exposure longer than 30 sec., but recently I was shooting Milky Way, turned the noise reduction off, and got "snow" all over the images. Here is the sample crop, on just 63 sec. It's a nightmare to clean all of it manually. What should I do now?
As I remember, Capture One can remove all of the white dots. Raw Therapee can too. I used them both, they got the job done.
10-15-2018, 10:10 AM   #512
QuoteOriginally posted by Markovo Quote
I've been looking at Capture One for K1 white dot removal. I currently have their 30 trial. I find that it works well, however in terms of coloring I like the output from LightRoom better (but LR does not do anything for the white dots). Also, I hate to spend $300 for C1 and really only use it to clean the dots.
I have not heard about Raw Therapee's capability to clean off the white dots. Using Raw Therapee what would be the process/approach to use in removing the white dots? I've used Raw Therapee very little....
10-16-2018, 02:01 AM   #513
Markovo's Avatar
QuoteOriginally posted by interested_observer Quote
I don't remember, but I will check it for you. Give me 2-3 hours.
10-19-2018, 09:10 AM   #514
I had some success using this method - How to remove Hot Pixels in Photoshop
Need to be careful and play with amount/threshold.
10-19-2018, 10:23 AM   #515
Find the "Impulse Noise Reduction" function, enable it and you are done. You can adjust the threshold if need be, but the default value is usually fine.
10-19-2018, 03:18 PM   #516
Markovo's Avatar
QuoteOriginally posted by Gimbal Quote
Yeah, that's the one!
10-19-2018, 09:27 PM   #517
QuoteOriginally posted by awscreo Quote
I need to start using Raw Tharpee a lot more I guess.... Thanks!!!!
astro, camera, data, dfs, dot, dslr, exif, exposure, exposures, ff, full frame, full-frame, heat, issue, k-1, k-1 white dot, k-5, k1, nikon, noise, pentax, pentax k-1, type, viewer
White Dot on 50mm f1.4 Super-Tak roboticspro Troubleshooting and Beginner Help 7 07-20-2018 01:47 PM
For Sale - Sold: White Pentax K-r + White Kit Lens + 2 Extra Batteries + 1 Extra Charger MightyMike Sold Items 2 04-14-2015 07:21 AM
Lost white dot bassek Pentax SLR Lens Discussion 15 09-06-2012 10:22 AM
white dot on live view screen Shingkyo Pentax K-r 7 03-14-2011 06:54 AM
old lenses- that little plastic white dot? dandaniel Pentax SLR Lens Discussion 6 02-25-2009 02:13 PM
All times are GMT -7. The time now is 09:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
