Originally posted by Gimbal I just noticed the weirdest thing while looking at your 100% crop, there is a lot of hot pixels of red, green and blue type but not white. That looks kind of normal (except perhaps the huge amount of them), but "my" long exposures do not have any green hot pixels, they are blue, red and white.
So much depends on the raw converter used that I don't now what to think anymore. The red and blue ones are usually larger than one pixel, forming a little cross or line of 2-3 pixels, while the white dots are single pixels standing alone. (How is that even possible with a bayer pattern?).
Is there a chance you could upload the 120s exposure so that we (or I) could see how it looks in the raw converter I have? This to see if there is an actual difference in the files or if it is the raw converter that makes them look different.
It's probably caused by differences in different raw convertors and the interaction of two issues:
1) RGB channel gain: how much each of the 3 channels are boosted to compensate for Bayer color filter attenuation, sensor quantum efficiency, and the convertor's white balance setting. Generally, the red and blue channels get the biggest boost.
2) RGB interpolation: the red and blue channels are sparsely sampled so the convertor needs to synthesize the missing pixels which might convert a 1x1 hot pixel into a cross or blob depending on the surrounding RGB values and the image structure models the convertor uses for interpolation. The green channel is more densely sampled so the reconstructed green channel has smaller artifacts.
(it would be interesting the analyze the coordinates of the various types of hot pixels -- are they always located on even (or odd) rows or columns??)
