Originally posted by swanlefitte Does the k1 shutter go bottom to top or top to bottom.
According to my observations, it goes from bottom to top, i.e., the reverse direction that previous Pentax DSLR shutters used. The prior "bottom border" now becomes a "top border" and indicates that the light hits the sensor a bit too late. It seems likely that the radio trigger used, isn't quick enough, although 1/200s is not really a challenge.
I don't have that problem with my Cactus V6II and my K-1 even at much higher shutter speeds. In other words, it is not the K-1 that is at fault here.
@dcpropilot: Are you still using Yongnuo triggers? They don't really support Pentax and some of their models require a wake up to work well beyond 1/160s. IIRC, the respective model was quite old though.
