08-07-2016, 06:35 PM   #1
gerardbaron's Avatar
K-1 AF viewfinder problem
I am having problem with the AF on the viewfinder with the 28-105mm
when the lens is extended after about 80mm.
I am using point focus.
I reset all the setup with no success.
AF works fine in liveview
I think the problem came when I update the firmware to 1.20.
Any suggestions?
Thank for your help
08-07-2016, 06:52 PM   #2
SteveD's Avatar
May not mean a thing but did you read the thread https://www.pentaxforums.com/forums/190-pentax-k-1/327333-strange-af-issue-da-300-a.html?
08-07-2016, 07:05 PM   #3
AF problem
Yes I read this thread, I did what it is recommended with no success.
08-07-2016, 08:07 PM   #4
I don't own either the K-1 or the D FA 28-105, but I will ask the standard hard questions:
  • What do you mean by problem? Does the camera not attempt AF? Is it unable to attain focus? Is focus inaccurate? Something else?
  • Do you have problems with PDAF (viewfinder AF) with any other lens?
  • Have you been able to test your 28-105 on another Pentax body?
...and lastly...Both camera and lens are still under warranty. Have you been in conversation with Ricoh/Pentax? If either lens or camera is less than a month old, have you been in conversation with your dealer to arrange for possible exchange?
08-07-2016, 10:16 PM   #5
Grognard's Avatar
I think K-1 users may refer to this issue as "PDAF Freezing", because the lens doesn't move at all, but the AF signal is flickering.
From all my observations and personal experiences I speculate that this issue attributes to Pentax's SDM design deficiency which cannot be handled well by K-1.
The reason: My DFA 24-70 (a Tamron rebadge SDM, you guys all kown) is clearly free of such issue. But DA* 300 and DFA 28-105 (mentioned by the original poster) both use Pentax's own SDM, which does not own a good reputation among Pentaxians.
Now that the "PDAF Freezing" issue can be solved by switching to CDAF, I hope this issue can be setteled by a future firmware release. I will add this point to the pinned thread.
08-07-2016, 10:55 PM   #6
QuoteOriginally posted by Grognard Quote
It is very short cut to a conclusion. What I know for sure is that the DFA150-450 and DFA70-200 supposedly Ricoh design (like DFA28-105) have totally different SDM designs, there is no comparison with "old" DA300 SDM, I don't know about the DFA28-105.
08-08-2016, 01:06 AM   #7
The D FA 28-105 doesn't use a SDM motor at all - it's using a DC motor. But I'm not sure if the difference is relevant in this case.
08-08-2016, 04:58 AM   #8
Paul the Sunman's Avatar
QuoteOriginally posted by gerardbaron Quote
Any suggestions?
Thank for your help
I've had no problem with this combination, and am on 1.20.
08-08-2016, 12:10 PM   #9
Any suggestions?
Thank for your help
I try the FA 28-105mm on a K-5: same problem
I mount another lens on the K-1. AF works like a charm
So I decide to return the lens and exchange it for a new one 20-105mm same lens.
The new lens works perfectly.
Problem solved.
af, dslr, full frame, full-frame, k-1, k-1 af viewfinder, k1, pentax k-1, viewfinder
K-x viewfinder lens coating problem. nikiu Pentax DSLR Discussion 6 01-20-2014 11:21 AM
Pentax K-7 Viewfinder problem nassestrasse Troubleshooting and Beginner Help 3 05-14-2012 09:27 AM
k-r viewfinder problem mynewkr Pentax K-r 5 12-02-2010 05:31 PM
K-x viewfinder problem ?? eastbay Troubleshooting and Beginner Help 2 11-05-2010 09:01 PM
K-x with new metz 58 AF-1 wireless problem shawnrnicholas Flashes, Lighting, and Studio 5 10-29-2010 01:16 PM
All times are GMT -7. The time now is 12:15 AM. | See also: NikonForums.com, part of our network of photo forums!
