08-14-2016, 08:04 AM   #1
Remote shutter for K1
Anyone have any recommendations for a remote shutter release for the K1? the one I have for my K5 doesn't work with the K1, only trips the shutter in B mode . Its the JJC RM-E7 remote control
08-14-2016, 08:35 AM   #2
I use the following wired remote with my K-3 II and K-5IIS. It derives its power from the camera, so it does not require a battery of its own. I tried IR remotes, but the batteries did not hold a charge consistently. I use it to stop/start long exposures.
http://www.bhphotovideo.com/c/product/765659-REG/Vello_RS_C1II_RS_C1II_Wired...981&
08-14-2016, 08:48 AM   #3
QuoteOriginally posted by C_Jones Quote
https://www.bhphotovideo.com/c/product/765659-REG/Vello_RS_C1II_RS_C1II_Wire...981&
OK, was an easy fix in the menu settings, my error-- it's working as it should
08-14-2016, 08:48 AM   #4
https://www.bhphotovideo.com/c/product/765659-REG/Vello_RS_C1II_RS_C1II_Wire...5981
I have used this in my K5. K5-IIs. K3 and K1. I got two of them figuring that since they were so inexpensive I would have a backup if one failed. Still haven't opened the second one.
08-14-2016, 08:52 AM   #5
QuoteOriginally posted by gaweidert Quote
it worked fine on my K5, but I forgot to adjust the settings in menu and now it works as before now on the K1 so its good!
08-14-2016, 09:11 AM   #6
TomTom's Avatar
QuoteOriginally posted by gsande2016 Quote
I have that exact remote and used it successfully this morning with my K-1 in M mode. Glad to hear that it's working for you now.
08-14-2016, 11:57 AM   #7
Glad you were able to set it up.
---------- Post added 08-14-16 at 02:58 PM ----------
It really works well, and the price is nice.
08-14-2016, 03:46 PM   #8
Hello,
I use my Android OS phone (different apps) .
Don' t know if it works on the k1.
Bye!
08-14-2016, 05:11 PM   #9
WPRESTO's Avatar
BTW: I use the Vello wired remotes and also two models of their wireless remotes and all of them have been 100% satisfactory on K20, K5, K3 and now K1.
08-14-2016, 05:25 PM   #10
I have been using an an app called DSLR remote on my android phone (LG G2) without any problem.
06-24-2017, 02:45 PM   #11
I tried the DSLR remote app for my K-1 and it does not work. It is not WIFI only audio and IR and could not get either of these to communicate with it.
06-24-2017, 03:14 PM   #12
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by wings Quote
But does your phone have an IR Blaster built into it for the app to use?
06-25-2017, 09:32 AM   #13
Good question
I did not see that on my phone, but will look into it. Thanks for pointing that out to me. I suppose that I am a tyro in that area, apps etcetera.
06-27-2017, 09:45 PM   #14
I have several wired as well as two different Pentax remotes. I prefer the wired shutter releases because of reliability. The Pentax is a bit pricey, but it turns out the remotes for canon typically work and are both easier to find and also cheaper. I also have a Chinese knock off called an aperture with a nice long cord and it is reliable. Haven't tried them on my k-1 but will in the next few days- I expect them all to work as they have on several prior bodies.
06-28-2017, 08:31 PM   #15
I used to use LG G2 and the DSLR remote app works without any problem. Now, I use a LeEco 3, which DSLR remote app doesn't support. But the ir remote app from the manufacturer could learn from the LG G2 and it also works. You probably need to find a smart phone that has an IR blaster built-in, which is not common nowadays.
Good luck.
dslr, full frame, full-frame, k-1, k1, pentax k-1, shutter
Suggestions for remote shutter release cable / remote Sean Hamilton Troubleshooting and Beginner Help 8 06-09-2016 07:15 AM
Shutter Question for K1 on a bellows unit. MichaelErlewine Pentax K-1 & K-1 II 2 06-06-2016 07:05 PM
Remote shutter release for K-50. Dewman Pentax DSLR Discussion 2 03-18-2015 05:03 PM
Remote Shutter Release for 645Z uintaangler Pentax Medium Format 3 03-05-2015 03:27 PM
All times are GMT -7. The time now is 12:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
