[EDIT - added]: At this point the horse is not only dead, it is glue. DPR has altered the review and no one will change the Conclusion or their opinion. Whatever damage shall have occurred has occurred.
A
GOOD test is set up in a controlled, repeatable environment so that
Data gathered accurately reflects differences in the tested subjects (the camera/lens combos); and such data has relevance to real world utility when tested subject results are ranked. Real world utility must be demonstrated (or the results are irrelevant). The ranking table thus becomes
Information.
I contend the DPR test results are not Information and the conclusions are not supported. The results are merely raw data gathered.
What we learned from DPR is, if your use case is to slap a 36Mp FF dSLR and f/2.8 70~200mm zoom on a tripod and burst photograph a weaving bicyclist in uncertain lighting at f/2.8 and 200mm (using unclear camera settings), the Pentax combo will miss focus more than half the time.
I do not believe those specific parameters were used in any comparison test. As DPR stated, "The test evolved over time."
Ergo we do not know that
any other 36Mp FF camera, or any other camera could achieve a higher in-focus score under those specific circumstances, and we surely do not know the K-1 tracking AF.C is "Poor. Not suitable for Action (small active children)".
