I've been having this issue with the K-1 for ages now, basically since I got it. I am in PST and the time keeps on setting itself to one hour ago. The situation basically is that I'll pick up the camera at the start of a shoot and check the time. If it's 4pm now the clock will say 3pm. I sigh, go into the menu, adjust the time, set it to 4pm, save settings, menu to exit. Shoot shoot shoot.
Next day, pick up camera at 11am and check the time, and it's now 10am. Change time, repeat, etc.
A few things I've done:
- My local and travel time are both set to PST (Vancouver)
- I've been unable to figure out exactly when it resets. I can turn the camera off and on and the time stays accurate, same with taking the battery out and putting it back in. I've had it reset in the middle of a shoot as well, I don't remember what I did at that time other than maybe going into the menu for some unrelated reason
- I'm definitely hitting 'save settings' after setting the time.
- I haven't noticed if the minutes are affected
- I haven't seen it reset after putting a different (or the same) memory card out and in.
This is getting *very* frustrating and annoying. It's always exactly one hour like it was a DST setting that keeps on changing (I have DST off and it isn't resetting) and the date and time are unaffected.
Is anyone else having this? Should I look at a replacement? I emailed Pentax through their support form but got no reply
