Originally posted by MarK-1 For K-1 / DA300mm users: What is your experience with this combo? Did you manage to find a setting that improves the autofocus, both in accuracy and (tracking) speed?
Hi MarK-1, welcome to the forums.
The K-1/DA*300 is a very good combo actually.
Having said this it's been a while since I've had mine on the K-1, but on that occasion it was my first opportunity to do some action shots with the combo. And whilst I do have to acknowledge it is slower than the D-FA* 70-200 and D-FA 150-450, the images from the DA*300 are worth the effort.
I have several images using the K-1/DA*300 combo on my Flickr stream that show the combo can AF and capture nicely detailed images. The DA*300 is streets ahead of the 150-450 if you need to shoot wide open. I've never had an issue shooting the DA*300 at it's widest aperture so if you need to be longer than 200 and the light is not good the DA*300 is likely to be more flexible due to it's performance at F4. The newer D-FA is nice and sharp too, but I've taken to stopping down to f7.1-f8 to avoid the softness wide open. As mentioned already, it's probably the SDM that is slowing the DA*300 during AF but you have the ability to manually focus whilst in AF to assist if it's starts racking back and forth or is slow catching up to your subject.
To aid the AF I recommend you set up the camera to use back button focus. This is quicker to focus with and allows you to concentrate on tracking without having to balance the shutter half press as the K-1 has a very light shutter. Try both shutter release options. With AF-S it might be best to set it to focus priority. With AF-C I use back button focus and release priority. I will get some extra images that are out of focus but more chance of getting images in focus.
For action I'm obviously using AF-C and have primarily been using centre weighted metering and zone select (9 AF points). I usually leave it on zone select when I go back to AF-S as well. I've not yet tried all the focus setting options, but have found with moving subjects that the central spot is harder to track with, which maybe just me but I've had a better keeper rate using the zone select option. Other's should be along to provide feedback on their expereince too I hope.
The next point to consider is whether you intend to shoot in RAW and gain access to the full resolution of the camera or use the crop mode or jpegs to gain access to faster camera function and better buffer response. One of the problems with the K-1 for action photography is the large files writing to the card. As I'm using full resolution and RAW I'm accepting a compromise that the camera will be slower but those images I do get will be larger. This can be a real pain but that has meant I changed the way I capture action shots. I've tried using continuous medium and low, but motorcycle racing is too fast for this approach so I tend to leave it on continuous high and accept that I need to pause regularly for the camera to write to the card. You have three options for continuous shooting so try them and see if they suit your work.
I now need to admit my bias for this lens. I've always liked the DA*300 and consider it one of the best Pentax lenses available. Yes SDM can be a pain and it would be nice to see an updated DC version, but it's a great lens now IMHO.There might be better lenses suiting your needs, but I'd suggest that you give this lens a go with different technique before looking at something else.
Anyhoo, hopefully the above will assist.
Tas
